Post this in one of the customization groups if you don't know Lisp/VBA/.NetOriginally Posted by 03xtreme
You should be able to do it programatically which would make this re-linking a snap once it's done.
I have a menu item that inserts a block w/attributes. That block's attributes hold duplicate atribute information that exists in other blocks. A little lisp code automatically adds the fields for the linking upon insert.
Unless you wrote it so that a reactor monitored the copy/paste and ran automatically, you'd have to manually initiate the running of the code after you inserted into the new layout but a single click should then be all it takes to perform the relinking.
