Results 1 to 10 of 10
Thread: Revit PDF Writer 4.2 Installation Problem
    100 Club dnilsson's Avatar
    2003-12
    Atlanta, Georgia
    109
    Default Revit PDF Writer 4.2 Installation Problem
    I cannot get this pdf writer to install on my machine. 25 other computers in the office work fine, but this is what I get:
    1. Install using the downloaded exe file.
    2. Get error saying that it is already installed (it does not show up in the printer listings.)
    3. Go to control panel, remove programs, and sure enough it shows up there.
    4. Remove it, get the error saying it cannot be found, but it deletes something anyway.
    5. Try installing again, get error saying driver could not be installed but the operation completed succesfully, click ok, get error saying installation must be aborted.
    6. Go back to step 3.
    So in a nutshell, I can't add this one printer driver to my system and I don't know why. My IT person has no idea and it's not high on his list of priorities, and like I said this is the only computer that does this. It would seem the problem lies with something outside of Revit. Using Windows XP Pro, but I don't know much about the inner workings of it.
    Anyone ever experience a similar problem?
    "Why must everything be so hard?!"
    -Homer Simpson
    2001-12
    Irvine, CA
    7,567
    Default Re: Revit PDF Writer 4.2 Installation Problem
    Happened to me recently as well on a XP Home version OS. After I removed the application through Add/Remove Programs I shut down the computer and did a "Hard" reboot...meaning I turned off the power completely, not a "Shut down>restart". When powered back up, the pdf writer installed correctly. Also make sure you are logged in with admin permissions. Good Luck!
    2003-12
    Atlanta, Georgia
    109
    I've tried soft and hard boots before and after installation, logged on as administrator, no dice. I'm at a loss.
    -Homer Simpson
    2003-12
    Atlanta, Georgia
    109
    Thought I could be clever and share the pdf writer from another machine.
    Nope. It looked like it was working, but it didn't.
    -Homer Simpson
    2001-12
    Irvine, CA
    7,567
    One more thought, open the Printers folder, then choose FILE>SERVER PROPERTIES...see if the Revit pdf driver is in the list. If is is, remove it, reboot and try again.
    2003-12
    Atlanta, Georgia
    109
    It was. I deleted it, rebooted, same result.
    I was hoping to avoid using Acrobat, but it looks like I'll have to bite the bullet and set that up again.
    I appreciate the suggestions Steve.
    -Homer Simpson
    I could stop if I wanted to studio3p's Avatar
    2003-06
    Manitou Springs, Colorado
    257
    Quote Originally Posted by dnilsson
    I know this isn't an Adobe forum, but I have been using Acrobat 6, and all is well except I get a very light grey tone background to every document I create using Acrobat. The problem doesn't occur when using DWF writer. The tone is light enough that I don't see it on screen, but when the pdf is printed the tone shows up within the printable area (whether out of house at a reprographics place, on my plotter, or on my desktop laser and inkjet printers).
    I posted this question on the Adobe forum, but not response. Anyone else experiencing this issue?
    2001-12
    Irvine, CA
    7,567
    One more...should have mentioned it earlier...remove the port associated with the Revit PDF Pinebush...same location, PORT tab
    2004-05
    17
    I have similar problem and was told by support that it was a registry problem. I have not had the guts to delve so am awaiting delivery of new notebook.
    AUGI Addict blads's Avatar
    2015-10
    out cycling somewhere... I wish...
    2,284
    Quote Originally Posted by studio3p
    Studio3P ,
    I've only had this problem with some image files generally get a nice background
    Cheers @blads
    Mac Geek | Building Design Suite 2020 | Semi-Retired Building Designer / CAD-BIM Trainer | Autodesk Certified Professional
  1. 2012: Revit SP.Writer - Installation questions
    By mrauscher in forum Revit Architecture - General
    Last Post: 2011-09-07, 05:24 PM
  2. installation dwf writer 4 geht nicht
    By akaiser in forum Deutsch - Inventor
    Last Post: 2008-07-24, 01:49 PM
  3. Revit 9.1 installation problem
    By dpasa in forum Revit Architecture - General
    Last Post: 2006-09-04, 04:47 AM
  4. Problem with PDF writer
    By tbowland.65401 in forum Revit Architecture - General
    Last Post: 2005-01-17, 11:17 PM
  5. Problem with PDF Writer
    By mtogni in forum Revit Architecture - General
    Last Post: 2003-11-28, 02:29 PM
