Results 1 to 7 of 7
Thread: 3D Orbit
    2004-06
    3
    Angry 3D Orbit
    I am working on 2004. I use the windows standard right click customization. The short cut menu that is displayed by a right click during an active command has 3D orbit listed. If the 3D Orbit is accidentially selected my AutoCad FREEZES, and I am then forced to retrieve my last autosave in amongst the trees of storage. Is there a way to delete the 3D Orbit from the shortcut menu?
    13,657
    Default Re: 3D Orbit
    Hi
    Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
    ID: TS84758 - AutoCAD crashes when 3D ORBIT used
    ID: DL4300874 - AutoCAD Sometimes Fails During Use of 3D Orbit
    ID: DL404081 - AutoCAD® 2004 Service Pack 1a
    Have a good one, Mike
    2004-06
    3
    Question Re: 3D Orbit
    I have tried the .dll file with no resolution. I have searched the mnu file and I can not find the correct pop for the shortcut menu. Do you know which one it is?
    2015-12
    Arizona
    2,478
    Quote Originally Posted by cconner
    Peek at these:
    http://usa.autodesk.com/adsk/servlet...linkID=2475323
    I'm thinking that you will need to remove and redefine the 3d orbit command name.
    2002-04
    Apologies first, it's not a solution to the problem, but I experience similar crash when attempting the 3DORBIT command running AutoCAD Mechanical 2006 (sp1a). I have recently upgraded from 2002 in which I used the orbit commands frequently and without problem (I must have become dependant) short of using multiple viewports I am lost without the functionality.
    2004-07
    Detroit Michigan
    2,508
    How good is your computer? I had all kinds of issues with a pentium 4 machine I used to run. I have yet to have similar problems since either upgrading or switching to 06.
  1. 2008: 2d orbit.
    By cadgiri in forum AutoCAD General
    Last Post: 2012-12-01, 11:27 AM
  2. 3D ORBIT TARGET
    By richardronan in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-10-15, 07:52 PM
  3. Center Orbit Pivot with orbit tool
    By joe.williams in forum Design Review - Wish List
    Last Post: 2008-07-28, 08:55 PM
  4. 3D orbit in LT?
    By Jordan Truesdell in forum AutoCAD General
    Last Post: 2008-05-14, 01:46 PM
  5. 3D orbit
    By dzatto in forum ACA General
    Last Post: 2007-04-16, 06:08 PM
