Thread: Flood Trace Analysis
    2006-09
    2
    Default Flood Trace Analysis
    Hello Everyone,
    Does anyone know how to get the flood Trace Analysis to show the exact distance I specify in my parameters. It only maps a line to the closest node? I have found a way to get the final distance but it is a long process and I have ALOT of segments to measure.
    Thanks in advance
    2006-08
    20
    Default Re: Flood Trace Analysis
    I think you have to define the maximum and minimum resistance according to your need while analyzing the flood trace analysis.
  1. Network Flood Analysis
    By trconnet in forum AutoCAD Map 3D - General
    Last Post: 2008-02-26, 06:05 PM
  2. VE and Trace 700 for Energy Analysis
    By mccurdyks in forum Revit MEP - General
    Last Post: 2007-09-14, 07:45 PM
  3. Flood Trace Analysis
    By amorris.120609 in forum AutoCAD Map 3D - Wish List
    Last Post: 2006-09-15, 03:25 PM
  4. Export Flood Trace to shapefile
    By kevin.bell81772 in forum AutoCAD Map 3D - General
    Last Post: 2005-08-19, 03:13 PM
