tlagace
I recently came across the problem of my rebar not having any thickness in elevation view, no matter what size it was. Although this will just adjust the line weight, you can apply different settings to each rebar style. Here are the steps to take.
1. Go to Setting, and Object Styles.
2. Select Structural Rebar, Go to the Modify Subcategories box, and hit New.
3. Give it an name (ex. Rebar #15M) and make sure the subcategory is Structural rebar.
4. Hit Apply and then OK.
5. Highlight desired rebar and choose Properties.
6. Go to Edit/New
7. In the Subcategory box, pull down the menu and choose the subcategory you created.
And voila, a simple walk around the fix the presentation of your rebar. Hope this helps!
Cheers
