Results 1 to 8 of 8
Thread: Starting Out
    2006-09
    England
    80
    Default Starting Out
    I am starting out with Revit building. We are a structural engineering company but have Revit 9.1 building. Revit structure wasn't out in the UK when we purchased it.
    I have worked through the tutorials but am still having problems. I find it hard to find time to practice on Revit while being busy doing active projects on Acad 2007.
    Therefore I have started an active project on Revit to try and get up to speed.
    I have some basic problems, I don't know how to create a curved beam, and I have found the In place family tutorial not very helpful.
    I would also like some steel hangers to fix to u/s of beams, currently I am offsetting from the top of steel datum.
    I appreciate these are basic questions so my real question is........Can someone recommend a good tutorial book for me that addresses problems like these.
    Thanks in advance
    2006-09
    England
    80
    Default Re: Starting Out
    Is it cos I am new to Revit and Augi that no-one will answer me
    Or have I comitted a cardinal sin?
    If you like we could also discuss something I do know about...Like the genius of Eric Cantona
    Active Member joshua's Avatar
    2005-11
    Santa Rosa, CA
    52
    Quote Originally Posted by pauleastwell
    You need to give it more than an hour.
    Try this website for informative easy to follow tutorials- http://www.dgcad.com/Revit9.htm.
    You might also want to search for Revit books on this forum, here is one of the links.
    http://forums.augi.com/showthread.ph...ht=revit+books
    Best of Luck
    J
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,273
    I really do not think there are any Tutorial Books as such. There is a new video tutorial available from CDV Systems (http://www.cdvsystems.com/courseware.php) that covers family creation. You will get lots of help here, never worry about that. It is a good idea though to to some searching on a topic that you are having with before posting. "Curved Beam" for instance turns up several threads that may be of interest.
    Joe
    Active Member david_spehar's Avatar
    Cleveland, Ohio
    98
    You might also want to post this on one of the Revit Structure Support forums (this forum is great but you run the risk of having a bunch of architects ganging up on you).
    2006-09
    England
    80
    Thanks to you all, I will do some searching.
    2006-09
    England
    80
    I just cant get to grips with this.
    I am impatient and that doesn't help, but how difficult can it be to place a UB, curved, on plan.
    I am finding the conversion from ACAD 2007 to Revit extremely difficult. The tutorials tell you how to things but dont explain why you are doing them, therefore it's difficult to relate into actual projects.
    I have managed to complete the coulmn grid and beam layout of a fairly difficult structure but I still find Revit rather frustrating.
    I am also aware that I am not commiting enough time to Revit.
    I feel like I'm the old dog that cant learn the new tricks and I am frustrated.
    I remember being a young lad just opening up Acad R8 or so and running with it. Not so with this.
    I should really put in the hours!
    Rant over
    2004-10
    Yorkshire, UK
    402
    I am in a similar boat, but have been using Revit a bit longer - It gets better, trust me!
    Once you get the hang of families (which I still havent done) things will seem much simpler
  1. 2002: Starting Up
    By dougurquhart676895 in forum AutoCAD General
    Last Post: 2014-07-23, 10:18 PM
  2. 2011: Help not starting
    By jonathan.landeros in forum Inventor - General
    Last Post: 2010-07-30, 05:00 AM
  3. Starting Out
    By Clarence Worley in forum Revit Architecture - General
    Last Post: 2006-09-15, 05:03 PM
  4. starting out in ADT
    By scott.91425 in forum ACA General
    Last Post: 2005-08-09, 02:57 PM
  5. starting off
    By cadmecheng in forum New Forum Users (Non technical)
    Last Post: 2005-06-22, 12:23 PM
