Thread: Need help verifying file exists
    2005-08
    378
    Cool Need help verifying file exists
    Could anyone assist me please.
    I am not sure what I am doing wrong ?
    Below is the first part of my routine and not all is relevant. I am stuck with the last part, trying to check if the file already exists to see if I need to replace the file "y" or not.
      (setq drawprefix (getvar "dwgprefix"))
      (setq drawname (getvar "dwgname"))
      (setq bldlvl
      (strcase (getstring "\nBuilding Level ie: B1, G, L1 or R? ")
      (setq currentdirectory
      (strcat (getvar "dwgprefix") (getvar "dwgname"))
      (setq newdrawname (strcat "XR-A-" bldlvl))
      (setq num 17)
      (setq strlength (strlen drawprefix))
      (setq newnum (- strlength num))
      (setq ammenddrawprefix1
      (strcat (vl-string-right-trim
         (substr drawprefix newnum strlength)
         drawprefix
      (setq newdirectpath (strcat ammenddrawprefix1 newdrawname))
      (setq check (findfile newdrawname)
      (if (= check newdirctpath) (command "saveas" "r14" newdirectpath "y") (command "saveas" "r14" newdirectpath))
    [ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]
    Would be most great full.
    Seems to work when the "If" options are (princ "\n...) rather the (command "saveas" ...)
    Not sure, Should I be using the "cond" function ?
    regards
    stephen
    Last edited by Opie; 2006-09-18 at 01:22 PM. Reason: [CODE] tags added, see moderator comment
    2003-09
    31
    Default Re: Need help verifying file exists
    You forgot an e in your statement.
    if (= check newdirEctpath) (command "saveas" "r14" newdirectpath "y") (command "saveas" "r14" newdirectpath))
    I am not sure yet if this is The bug, but it IS one.
    2003-09
    31
    I put this code Visual LISP and found one error with closing brackets.
    I know that a popular translation of LISP is "Lost In Stupid Parentheses"
    but you must check it or else......
    In this piece you need 1 more closing bracket.
    In addition to my first reply some explanation:
    The variable newdirctpath (without a "e") has a value of nil so the if-statement will always do the else (e.g. second) option. When the file exist you get an "error" because AutoCAD ask to confirm the replacing off the old file.
    All AUGI, all the time Avatart's Avatar
    2004-06
    Upsidedown in dreamtown
    928
    Below is a snippet of a routine I use to bind in Xrefs, this part of the routine is to check to see if a file exists and set a variable accordingly:
    (setq bindpath (strcat (getvar "dwgprefix") "Bind\\"))
    (setq savename (strcat bindpath (getvar "dwgname")))
    (if (/= (findfile savename) nil) (setq exist 1) (setq exist nil))
    (if (/= exist 1)
     (DoBind)
    (if (= exist 1)
      (progn
     (alert "Bound Version Exists")
     (initget 1 "Yes No")
     (setq boundoverwrite (getkword "Bound Version Exists - Overwrite? (Yes/No)"))
    	(if (= boundoverwrite "Yes")
      (DoBind) (DoNotBind)
  1. 2015: FAMILY ALREADY EXISTS
    By gordolake in forum Revit Architecture - General
    Last Post: 2014-08-26, 11:29 PM
  2. 2010: error: Unable to load customization file That customization Group already exists
    By aheintze351177 in forum AutoCAD 3D (2007 and above)
    Last Post: 2013-01-09, 10:06 PM
  3. Replies: 0
    Last Post: 2011-05-30, 07:07 AM
  4. How to Find a Layer if It Exists?
    By BeKirra in forum AutoLISP
    Last Post: 2008-11-06, 01:25 AM
  5. Check to see if file exists
    By ccowgill in forum AutoLISP
    Last Post: 2006-04-10, 09:12 AM
