Results 1 to 10 of 17
Thread: Lines on X axis are drawn at varying Z axis
    2006-09
    8
    Default Lines on X axis are drawn at varying Z axis
    I have been using Autocad 2000 and recently started using 2006. I am working in 3D. Let's say I am on a front view. I click a point at random on the left side of the view and then move my mouse to the right slightly. I type in 5 and enter so as to make the line 5 inches long. When I go to a top view the line has different starting and ending z points. I have never had this happen before.
    2003-10
    San Francisco CA
    1,190
    Default Re: Lines on X axis are drawn at varying Z axis
    When in the front view if you pick a point at random and don't snap to existing geometry the line will start at the 0 elevation of the front view. When you change to the top view the line you created may or may not be near your existing geometry depending on how close your existing geometry is to 0,0,0.
    Does that make sense or am I completely missing your point?
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    2006-09
    8
    I think maybe I didn't do a good job of explaining. Lets say we start at a front view. Select a point at random or snap to an existing point of some sort to start the line. I have ORTHO on and I wish to make a line 5 inches to the right. I usually will just move my mouse to the right and type 5 and enter. For some reason when I go to a top view I discover the line starts at the desired z value but ends at some random z value. In the past when I have done this the line has allways started and ended at the same z value unless I draw the line and snap to points at different z locations.
    2003-10
    San Francisco CA
    1,190
    Sorry for the misunderstanding.
    Questions:
    When in the front few are you in the World Coordinate System (WCS) or a User Coordinate System (UCS)? My thought is you might be in a UCS that is skewed to the WCS.
    If you list the line you created in the front view is it 5 units long?
    Does the line appear straight in the front view?
    Not sure I have an idea what is going on just fishing for clues.
    Scott Telthorst
    2006-09
    8
    OK, I may have misrepresented the problem. It turns out that this only happens when I start the line from the quadrant of a circle and then try to make the line a certain length. It for some reason doesn't follow parallel in the z axis.
    2003-10
    San Francisco CA
    1,190
    Is there anyway you could post an example of the problem so that I can see if I can duplicate/figure out the issue?
    Scott Telthorst
    2006-09
    8
    Try it on this drawing. Start at the bottom quadrant of the largest circle and make a line going left 5 inches.
    2006-09
    8
    In case it is a setting in my autocad, here is the same drawing after I perform the above proceedure.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,194
    Have you looked at the OSNAPZ system variable?
    Quote Originally Posted by AutoCAD Help
    OSNAPZ System Variable
    Type: Integer
    Saved in: Not-saved
    Initial value: 0
    Controls whether object snaps are automatically projected onto a plane parallel to the XY plane of the current UCS at the current elevation.
    0 Osnap uses the Z-value of the specified point
    1 Osnap substitutes the Z-value of the specified point with the elevation (ELEV) set for the current UCS
    2006-09
    8
    Quote Originally Posted by Opie
    Changing it to 1 did stop it from doing this.
  1. 2014: Label Style Composer - Can't get component lines down to profile grid axis
    By PGP-LA in forum AutoCAD Civil 3D - Profiles
    Last Post: 2013-06-10, 09:57 PM
  2. 'Section box' in {3D} view can be rotated about X or Y axis as well as Z axis.
    Last Post: 2012-02-06, 07:34 AM
  3. How to plot duct axis lines ??
    By ncostab in forum Revit - Plotting/Printing/Exporting
    Last Post: 2010-11-12, 09:26 PM
  4. z-axis fillet between lines
    By eli_lied in forum AutoCAD General
    Last Post: 2009-03-04, 01:08 PM
  5. Correcting Lines which are slightly off the axis
    By harilalmn in forum VBA/COM Interop
    Last Post: 2009-02-05, 06:07 PM
