Thread: Using Procedural Bumps with Brick
    100 Club sfraney's Avatar
    2004-07
    Philadelphia,PA
    198
    Default Using Procedural Bumps with Brick
    Hello everyone.
    I noticed that Revit's brick materials have a feature under the "edit / map tab" called "Procedural Bumps". I assume that this is for bump mapping, would this be correct? If so, how can I enable the bump feature so when a brick veneer is rendered it gives the "bump" effect. Help on this would be much appreciated.
    2015-12
    Vancouver, BC Canada
    3,753
    Default Re: Using Procedural Bumps with Brick
  1. Model each brick on a brick wall
    By AP23 in forum Revit Architecture - General
    Last Post: 2010-06-18, 03:05 PM
  2. Procedural Maps Where?
    By narlee in forum Revit - Rendering
    Last Post: 2010-04-17, 11:08 PM
  3. Replies: 5
    Last Post: 2008-12-02, 01:00 PM
  4. 3ds MAX - Improved Tiles Procedural Shader
    By dellis in forum 3ds Max - Wish List
    Last Post: 2007-11-05, 07:33 PM
  5. Procedural question
    By Tyveka in forum Revit Architecture - General
    Last Post: 2007-02-01, 04:45 PM
