What program can I use to view an .skd file whitout having to buy anything?
Is there a way I can import it into AutoCAD 2005 or MicroStation V8?
Any help is appreciated.
Jason
Jason
Hi
Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
ID: TS64947 - Convert AutoSketch® software SKD file format to AutoCAD® or AutoCAD LT® software DWG format
Have a good one, Mike
This doesn't seem to work for a .skf file. Any suggestions? Thanks-
