Thread: BRE U Value Import
    All AUGI, all the time Roger Evans's Avatar
    2003-05
    South Wales UK
    828
    Default BRE U Value Import
    I might well be a bit slower here than some of you but a useful tip ..
    I was playing with the UK BRE U Value Calculator & trying to figure how to import the info onto drawings then found that looking at the calc in preview mode I was able to copy the calc & then import as text into Revit ... works a treat
    Retaining Walls ... Anyone know how to calculate U value for a retaining wall ?
    2003-04
    Scotland
    1,577
    Default Re: BRE U Value Import
    That is handy to know Roger, we use the BRE U value Calculator all the time.
    The basement Calc is a bit of a waste of time, it doesnt allow for only some of the walls to be retaining and appears to be only a floor?? will have to do this soon myself!! probably I would be tempted to ignore the earth beyond the wall, then you would know that your U Value you calculate would end up giving a better than required as the the earth would only improve the U Value. If you add a very big number as the thickness of the earth you will end up being told dont need any insulation, which you obviously would do.
    Playing around with floors though the earth does make a big difference. I did a floor with 1 layer a thickness of 1mm and a lambda value of 5000. (ie just the the earth being calculated)
    for floors I found
    clay alone gives a U value of 0.65
    sand gravel 0.82
    rock 1.25
    I used the lambda Values from floors and applied to a 1 layer wall (clay 1.5, sand 2.0 rock 3.5) I adjusted the thickness till the uvalue matched what I found above and I got -
    for clay (in a floor at least) it appears you could use a 750mm layer with lambda of 1.5 to represent the earth.....
    for sand a 2100mm layer with lambda of 2
    Suppose it depends if you need more or less insulation, I will probably go for ignoring the earth and just getting a well insulated wall when I have to do it...
  1. 2013: "Import detected no valid elements in the file's paper space. Do you want to import from the model space?
    By thomasmerrittgibson397439 in forum Revit Architecture - General
    Last Post: 2013-07-05, 06:53 PM
  2. Replies: 1
    Last Post: 2012-07-09, 03:09 PM
  3. Import from CAD to RSA
    By michaelfenton1 in forum Robot Structural Analysis
    Last Post: 2010-03-01, 06:56 PM
  4. import from RAM
    By Bryan Thatcher in forum Revit Structure - General
    Last Post: 2009-09-11, 08:22 PM
  5. IFC import for ADT
    By robert.lipman in forum ACA General
    Last Post: 2005-03-30, 06:40 PM
