Results 1 to 10 of 17
Thread: Get the current support paths and add new paths
    2001-10
    Defragging the internets.
    350
    Default Get the current support paths and add new paths
    I just wanted to share this with everyone. It will get the current support paths and add new paths.
    (SETQ ORIGPATH (STRCAT (GETENV "ACAD")";"))
    (SETQ ONEPATH (STRCAT "E:\\BMP;E:\\PROJECTS\\SSS;E:\\PROJECTS\\OUR_BLOCKS;E:\\PROJECTS\\OUR_BLOCKS\\Symbol_List;"));ADD PATHS HERE, NOT TO MANY OR IT GETS CUT OFF
    (SETQ TWOPATH (STRCAT "E:\\lisp;E:\\lisp\\LAYER-COLOR;E:\\lisp\\New_PANELS;"));ADD MORE HERE
    (SETQ THREEPATH (STRCAT "E:\\lisp\\NOT USED;E:\\PROJECTS\\OUR_BLOCKS\\Symbols;E:\\PROJECTS\\scripts;E:\\FONTS\\SHX;E:\\lisp\\lisp;C:\\Program Files\\Autodesk\\Migration Tools;"));ADD MORE
    (SETQ FOURPATH (STRCAT "E:\\lisp\\lisp\\BLK-INS"));ADD MORE HERE,NOTE - NO SEMI COL AT THE END
    (SETQ MYENV (STRCAT ORIGPATH ONEPATH TWOPATH THREEPATH FOURPATH))
    (SETENV "ACAD" MYENV)
    (strlen (getenv "ACAD"));DON'T GO OVER 800 OR BAD THINGS HAPPEN
    Let me know if this helps or if there are any improvements that can be made.
    Chris
    Earth
    9,809
    Default Re: Get the current support paths and add new paths
    You can also do it using the ActiveX object library as shown in this post [ http://forums.augi.com/showthread.ph...43797#poststop ]
    R.K. McSwain | CAD Panacea |
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,119
    Quote Originally Posted by FRAMEDNLV
    Chris
    Shouldn't you check for the length of the string prior to setting the environment variable?
    2001-10
    350
    RK,
    Thanks for the link.
    Opie,
    Which string? Are you referring to the total acad env or the current?
    From what I read the total (strlen (getenv "ACAD")) should not exceed 800 characters.
    I did try reseting the acad env by setting it to blank (SETENV "ACAD" "" ) and then adding the new paths. When I set it to blank AutoCAD will add the default support paths.
    So far it seems to be working in our mixed AutoCAD environment. No duplicate paths are being updated.
    Chris
    2002-01
    jUSt Here (a lot)
    9,119
    RK,
    Opie,
    Chris
    I was referring to querying the length of the path after you reset it with the additional paths. If your additional paths make the Support Paths be larger than the limit, shouldn't you know that prior to resetting the environment variable?
    2001-10
    350
    I thought about it for a while and decided to do as you suggested. I'll add the condition in the morning.
    If there doesn't seem to be any other problem with it I'm going to add it to our acad.lsp in the morning.
    Basically I'm setting the lisp for new and old cad stations. I still have a lot to work out (pc3 paths is going to be next).
    Chris
    2002-01
    jUSt Here (a lot)
    9,119
    Chris
    Shouldn't you verify those paths are not already in the support paths?
    Earth
    9,809
    Quote Originally Posted by Opie
    That's why in my method, I don't grab what's currently there and append it, I just set the entire path.
    2002-01
    jUSt Here (a lot)
    9,119
    Quote Originally Posted by rkmcswain
    I realise that. But I think the OP wanted to have the ability to append it to the current list. Not the best approach for an office. I would rather have everyone have the same paths as well.
    2001-10
    350
    I didn't have any duplicate path problems while testing it. My current support paths have some of the ones that are being added, but they don't seem to duplicate.
    Chris
  1. 2015: Support Paths Not Holding
    By Iceberg in forum AutoCAD Customization
    Last Post: 2014-09-16, 02:50 PM
  2. ACAD.lsp for support paths
    By zride91 in forum AutoLISP
    Last Post: 2012-06-28, 05:15 PM
  3. Relative Paths back to Full Paths Kind a rush thing
    By ReachAndre in forum AutoLISP
    Last Post: 2007-10-25, 11:21 PM
  4. Change full paths to relative paths?
    By RCA4697 in forum AutoCAD General
    Last Post: 2006-05-31, 02:19 AM
