Results 1 to 6 of 6
Thread: Looking for the functions used in AutoCAD
    2001-07
    318
    Default Looking for the functions used in AutoCAD
    Hello,
    I was reading the Visual Basic Reference in Autocad. I was looking for the functions about Autocad like info about line, How to manipulate, create..an entity (line, circle...)
    but nothing, "only" information about VBa.
    Do I've missed something?
    Thanks
    Turlock, CA
    5,682
    Default Re: Looking for the functions used in AutoCAD
    Online references consist of several 'books'. You're looking only at the reference for VBA. You need to look at the adesk Developer Guide. If you just hit F1 while you're in the IDE, you will go to the vba help. Switch back to the TOC tab and back up a few levels in the hierarchy, or hit F1 while you're in acad. You should see a link to 'ActiveX automation and VBA'.
    C:> ED WORKING....
    2002-02
    Kansas
    487
    Open the Object Browser ( View menu -> Object Browser) select the AutoCAD Object you are looking for then the F1 key
    Note:
    update to 2011
    I am using ADT 2007 08/06/2008
    PS. If you use any Code I post or Down Load Attachment I would like to know if it was helpful. So please post reply to this thread, on how you use the code or down load. Thank You
    100 Club wpeacock's Avatar
    2015-09
    Bunbury, West Australia
    161
    Quote Originally Posted by Ed Jobe
    Snip
    Ed
    This reference manual doesn't appear to be available.
    I'm using AC2006. Do you have to Load this refence manual from somewhere?
    Wayne
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,449
    Quote Originally Posted by wpeacock
    Ed
    Wayne
    Try the help system from AutoCAD. There is a link in AutoCAD's help to the Developer's help sections.
    Turlock, CA
    5,682
    You can manually load it if you want. It is acad_dev.chm. In fact I have made a shortcut to it in acad.cmd.
    C:> ED WORKING....
  1. Replies: 0
    Last Post: 2012-11-24, 07:38 PM
  2. If and functions...
    By awill81226338 in forum AutoLISP
    Last Post: 2009-08-18, 06:32 PM
  3. Replies: 5
    Last Post: 2007-05-04, 03:49 PM
  4. Programing help with map functions
    By bprabhakar001 in forum AutoCAD Map 3D - General
    Last Post: 2006-07-31, 10:06 AM
  5. I don't always use Map Functions...
    By aharris in forum AutoCAD Map 3D - Wish List
    Last Post: 2004-07-29, 02:10 PM
