- Many times, when I'm placing detail references in plan/section/elevation views, I can't remember what the "required" detail name is. But it's already on a sheet along with other similar/related details. I would like to "right click" on a view tag, and select a Select From Sheet option, that would take me to the sheet full of those similar details, allow me to "pick one", and then return me to the plan /section/elevation view that I was working in.
- Also a Go To Sheet option, that would just "hyperlink" to the referenced sheet, not the view itself.
- One more...
I tend to do a lot of reorganizing of the views and sheets, to optimize the readability of the set. I would like a Move View to Sheet tool, that would work like a "paste aligned" for views. Of course, currently Revit does not allow Control-X (Cut) of a view, which could be one way of achieving this. This would also enable the placement of "like views", in the same place on different sheets. Just Overlay two (or more views) on a single mastering sheet, then Move (or Ctrl-X) them onto their preferred sheet.
- OK last one...
Some way of aligning symbols and view reference tags to columns and rows in schedules, such that as the schedule changes (shrinks or grows, or otherwise is reorganized), the associated symbols and view reference tags stay in their assigned fields.
Graham
