Many of us have advocated a loft tool of some kind here on AUGI but we haven't been specific on how it should work, or why we would need it on a day to day basis. This thread should avoid discussion of marquee-type architecture like Gehry or Hadid -- why do you need it on YOUR projects?
Then, I think we should define how the tool works so the Factory can look at our requirements for this tool and think about how they'd make it happen.
I'll go first!
Minimum Requirements
Cross Section (Profile) Definition
Path Definition
- The tool should be able to blend lines, arcs, splines and ellipses in cross section
- There should be no limit to the number of cross sections that can be created along the path
- Cross sections could be added to any segment (perhaps toggled in a right-click menu) at the middle of the segment. Like a blend the object would blend in a linear fashion between one profile and the next.
- The profile would be perpendicular to the middle of the segment and perpendicular to the path
- The profile can be rotated, and could be either sketch-based or profile-family based
Applications
- The path should allow lines, arcs, splines, and ellipses
- The path should have no limit to the number of segments in the loft
- Initial versions of this tool would probably follow the Revit precedent of being workplane based. Later versions of this tool should be afford users the opportunity to develop the loft in a more freeform manner without always being constrained to a workplane
We have several uses for this tool already for which we are using workarounds.
I will post some examples here in this thread/post as examples of why we need this tool and what it would need to do.
- A decorative foam arch (or buttress) which follows a curving path in elevation and increases in size from where it attaches to the wall to where it attaches to the soffit
- Walls which curve in plan and whose top increases in height (there are many examples here on AUGI of others with this exact need)
- A roof with a certain cross sectional profile that turns through 90d and ends with another cross section profile (changes slope as it rotates)
- A tool for making roads (though being restricted to one plane with the path would make this an incomplete solution)
