Results 1 to 10 of 10
Thread: Reinstall Express Tools in AutoCAD 2005
    2002-12
    4
    Question Reinstall Express Tools in AutoCAD 2005
    I recently upgraded to Auto Cad 2005 and loaded Express Tools. I then installed Autodesk Raster Design and Express Tools vanished. I cannot reinstall Express Tools, only uninstall. How can I get it back?
    Thanks!
    2015-12
    Arizona
    2,337
    Default Re: Reinstall Express Tools in AutoCAD 2005
    First try a menuload and go get the express menu.
    Or go ahead and uninstall it, and THEN re-install.
    2002-12
    4
    What is the Express menu mnu?
    2002-12
    4
    Never mind. acetmain.mnu
    Thanks! That fixed it.
    3
    I'm hoping that someone here can answer this. I'm using AutoCAD 2004 and looking for the Pack and go command. I've looked at the help and it says that it is now a command line command. Does any one know what the command is?
    2001-05
    Austin, TX USA
    2,201
    Check out the etransmit command. It replaced Pack n Go.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    3
    Thanks.
    Could they of made it any harder to find. It would of been nice if they would of told you what command replaced the original. Thank you very much. I have problem with it but I think I need to create some more directories.
    2015-12
    Arizona
    2,337
    Roy,
    The FIRST thing one should do upon opening
    a new version hit that F1 key, enter the search
    value of "What's New". Therein the mysteries
    of the new version are revealed.
    Unless you enjoy the dance of the 7 veils.
    13,656
    Hi
    Just to echo Glenn's comment, take a look at the following thread -
    pakngo files
    Have a good one, Mike
    13,656
    Hi Hector
    Please note I've moved your post dealing with AutoCAD LT and Raster Images to the following location -
    Raster Images with AutoCAD LT
    Thanks, Mike
  1. Express Tools for AutoCAD LT
    By thechinaman in forum AutoCAD LT - General
    Last Post: 2006-08-18, 02:52 PM
  2. Install Express Tools with AutoCAD 2005
    By CadDog in forum AutoCAD General
    Last Post: 2006-03-22, 08:45 PM
  3. Replies: 8
    Last Post: 2006-02-23, 10:43 PM
  4. Installing Express Tools in AutoCAD 2005
    By akall in forum AutoCAD General
    Last Post: 2005-02-03, 04:37 PM
  5. Express Tools command PLJOIN in AutoCAD 2005
    By kgray.65984 in forum AutoCAD General
    Last Post: 2004-10-18, 06:24 PM
