I'm trying to define a roadway template. I have the road itself defined. Then i need a sidewalk at 2% grade either up or down depending on the cut/fill required to daylight, so I defined that in the Design Control under slopes and checked the hold at 5' offset. Then I want to slope at 2:1 until I actually daylight. How do I define this part? I tried messing around with the benches, but that will give you benches until you daylight, you can't hold it to just 1 bench and then daylight at the given slope. Any help would be much appreciated.
Steve
