Results 1 to 10 of 13
Thread: National CAD Standard Layers
    I could stop if I wanted to rhayes.99001's Avatar
    2005-11
    New Jersey
    349
    Default National CAD Standard Layers
    Is there a Drawing File out there with all the National CAD Standard Layers already
    set up.? If so where Can I find it.
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    Default Re: National CAD Standard Layers
    Not that I'm aware of... A lot of us have that need.
    (I like your Av)
    2011-05
    926
    This is not drawing dependent. Go to Format/Layer Management. Then you can select Layer Key Styles or Select Layer Standard. Depending on your version of ADT, you may be offered several layer key styles. Any of the AIA layer styles comply with the NCS, in that the NCS adopted without exception the AIA layer standards.
    The NCS is currently being revised, but the layer management portion is being expanded, rather than contracted. More choices are sometimes better.
    2002-09
    Madison, WI
    5,687
    Quote Originally Posted by rhayes.99001
    Depending on which (If any) Government Agency you are working with, you can download them from thier individual web site. The one I recieved was from the US Army engineer Research & Development Center. But Each Agency may have thier own. I know that the one I recieved from the US Army was different that the one I recieved from the Veterens Association. Of course you could always buy one. If I can find the website I got it off of, I'll post back.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    We were pretty ticked off that the CD that comes with the NCS didn't have drawings already setup on it matching the standards they've outlined.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2011-05
    926
    Quote Originally Posted by Steve_Bennett
    I don't understand that comment, since ADT OOTB includes the standards in the layer key styles.
    2002-09
    Madison, WI
    5,687
    I guess I wasn't really all that involved in getting that stuff set up. I was more mad that once someone set it all up for v2, v3 came out (And it was different) and then v3.1 came out (and that was also different). So we converted all the drawings we had already done for a current project only to find out that this particular faction decided that they didn't want to convert to the 3.1 standard. So we got to change all the colors back again. How fun is that. All I know is that we spent about 20 hrs to create a perfect script to convert one way, only to convert back to the way it was.
    2015-12
    4,730
    Quote Originally Posted by cgraham
    Well, what if I'm too lazy to extract all the layers for someone running vanilla autocad??? I'm back to square one...
    2003-03
    Philadelphia, PA
    2,392
    A simple LISP routine can create all of the layers from the Layer Key Style, but the Layers Defined in the Layer Key Style are a small subset of the layers described in the NCS.
    2015-12
    4,730
    Quote Originally Posted by dkoch
    Exactly...
  1. National BIM Standard
    By cadtag in forum CAD Standards
    Last Post: 2012-05-18, 03:11 PM
  2. National Cad Standard 4.0
    By JWB in forum CAD Standards
    Last Post: 2008-01-22, 09:54 PM
  3. National BIM Standard?
    By Wanderer in forum CAD Standards
    Last Post: 2007-05-11, 09:43 PM
  4. Using National CAD Standard with ADT
    By jasontirone in forum CAD Standards
    Last Post: 2006-12-07, 03:59 PM
  5. National Cad Standard
    By jbayne in forum ACA General
    Last Post: 2005-04-28, 12:30 AM
