BMcCallum
Another solution is to make a copy of the elevation tag, move the cut depth to the desired location and change it's view properties to Underlay. I name this view with the -BG suffix to remind everyone that it is the background.
Then, change the view depth of the original elevation to overlap the cut depth of the background elevation. Don't want to miss any objects, right?
Place the background on the sheet first and then drag the foreground to the sheet. The alignment lines will help you line things up.
The attached image shows on of these composite elevations.
