Results 1 to 7 of 7
Thread: Grouping Objects Quickly
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    Default Grouping Objects Quickly
    How about you just select objects to be grouped, then with a keystroke its grouped. If you dont care for the name of the group (there's only few who cares anyway...) the macro below quickly creates an anonymous group.
    ^C^C-g;c;*;;p;;
    If you're an extensive photoshop user, you might want to Replace the Ctrl-G (Grid Toggle) macro with this one. Besides F7 is always there to the rescue. Its always good to unite keyboard shortcuts of the programs you use.
    2007-04
    Default Re: Grouping Objects Quickly
    THANKS!!! Our office sorely missed the "old" GROUP command from AutoCad2000 LT.
    Have you a macro to quickly UNGROUP the newly created groups? EXPLODE and BURST do not work. Experimenting with your macro, I see one must use the new GROUP command and FIND UNNAMED and then EXPLODE w/in the GROUP dialogue box. Clunky, but at least it works and the GROUP part is great!!
    2005-11
    51
    It is not a permanent "ungroup", but have you tried Ctrl+Shift+A?
    2004-07
    Detroit Michigan
    2,508
    Cool! This tip looks like it will be handy.
    2007-05
    7
    Thumbs up Re: Grouping Objects Quickly
    Nice tip, like a lot of simple things like this, I use them so frequently but I never stop and take the time to make them simpler.
    When I can just paste in a command I don't feel like I'm taking as much time away from drawing
    I could stop if I wanted to kwong's Avatar
    2002-11
    270
    Ctrl+Shift+A only suspends the grouping, (Pickstyle = 0).
    I have a lisp routine that ungroups groups permanently:
    (defun C:ug (/ CNT PICKS SSET)
    (vl-load-com)
    (setq PICKS (getvar "pickstyle"))
    (setvar "pickstyle" 1)
    (princ "\nSelect groups to be exploded: ")
    (setq SSET (ssget)
    CNT 0
    (repeat (sslength SSET)
    (delete_group (get_groupname (ssname SSET CNT)))
    (setq CNT (1+ CNT))
    (setvar "pickstyle" PICKS)
    (prin1)
    ; This function returns the group name of an entity.
    (defun GET_GROUPNAME (ENAM / ELST PAIR SEL GRPNAM GRPOBJ)
    (setq ELST (entget ENAM))
    (if (setq PAIR (assoc 330 ELST))
    (progn
    (setq GRPOBJ (vlax-ename->vla-object (cdr PAIR))
    GRPNAM (vla-get-name GRPOBJ)
    GRPNAM
    ; This function deletes a group name from the groups collection
    (defun DELETE_GROUP (GRPNAM)
    (vl-catch-all-apply
    '(lambda (X)
    (vla-delete
    (vla-item
    (vla-get-groups
    (vla-get-activedocument
    (vlax-get-acad-object)
    X
    (list GRPNAM)
    (princ "\nC:EXPLODE_GROUP ")
    (prin1)
    There is also a lisp routine for 'grouping real fast' in CADALYST 05/04 Tip1948: GGR.LSP Group Objects (c) 2004 Stacey Conrad
    Atlanta
    118
    Almost 15 years later to the day, and I used this on several hundred room name blocks that had gotten corrupted, somehow each entity in the roomname block was a group with a wipeout. Thanks for saving me hours of tedium and frustration! Worked like a charm in 2020.
  1. Quickly convert similar MEP objects to another similar object
    Last Post: 2013-11-21, 06:00 PM
  2. Grouping??
    By pearlx100 in forum AutoCAD General
    Last Post: 2009-09-21, 05:56 PM
  3. Grouping
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2009-02-07, 12:38 AM
  4. Grouping.. maybe..
    By mjsregister in forum VBA/COM Interop
    Last Post: 2005-04-25, 08:18 PM
