Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: Error "library not registered" when trying to run LISP routine (LDT related)
    I could stop if I wanted to Hammer.John.J's Avatar
    2015-09
    Springfield, MA
    491
    Exclamation Error "library not registered" when trying to run LISP routine (LDT related)
    for some reason one of my associates gets this "library not registered" error when trying to use the following lisp and blocks
    it obviously recognizes the lisp because it thinks, for a millisecond then errors that message.
    These exact same routines work on my pc, what the heck? is this cui related or something. I've loaded the lisp every way possible with the same result.
    2015-12
    Central Oregon
    591
    Default Re: Error "library not registered" when trying to run LISP routine (LDT related)
    Open the Lisp in the VLIDE, place a breakpoint near the beginning of the routine, run it from ACAD, once it hits the breakpoint use the F8 key to step through and find which line it errors on.....
    Although you might try adding (vl-load-com) to the beginning....
    2015-09
    Springfield, MA
    491
    thanks miff,
    i'll try that when i get to work, what does that mean anyways?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by 03xtreme
    thanks miff,
    It allows you to step through the routine one expression at a time.
    You should look at the Debug menu for "Watch Last Expression". It will open another window and show you the result of the last expression.
    2015-09
    Springfield, MA
    491
    ok i did the watch and this is what i get
    Welcome to Visual LISP for AutoCAD 2006
    ; LPP kernel: IDE v.T.0* Mar 5 2005
    [ACADVER = 16.2s (LMS Tech)]
    ; kern VLLib: IDE v.T* Mar 03 1999, build #690 [3/5/05]
    ; "C:/Program Files/Autodesk Land Desktop 2006/VLLIB.DLL" loaded
    ; desktop restored from "C:/Documents and Settings/dank.OFFICE/Application Data/Autodesk/Autodesk Land Desktop 2006/R16.2/enu/VLIDE.DSK"
    LOG Watch
    SPTL40 = nil
    I can't figure out why it errors on everyone elses machine except mine? I also tried adding the (v-load-com) at the first line of the lisp and got the exact same error.
    2015-09
    Springfield, MA
    491
    (defun attsurf	(bname / acadobj aecapp aecProj aecsurfs aecsurf aecutil e-n
    		 emsg pt# selev appstr versn *error* att blk space)
      (defun *error* (msg / objlist)
        (setq objList
    	   (reverse
    	     (list acadobj aecapp aecProj aecsurfs aecsurf aecutil)
        (vl-catch-all-apply
          '(lambda ()
    	 (mapcar 'vlax-release-object objlist)
        (if	msg
          (princ (strcat "\n" msg))
        (princ)
      (setq appstr (cond ((= (setq versn (atoi (substr (getvar "acadver") 1 2))) 15) "2")
    		     ((= versn 16) "4")
    		     ((= versn 17) "6")
      (setq	acadObj	 (vlax-get-acad-object)
    	space    (vla-get-modelspace (vla-get-activedocument acadObj))
    	aecApp	 (vla-getinterfaceobject acadObj (strcat "Aecc.Application." appstr))
    	aecProj	 (vlax-get aecApp "Activeproject")
    	aecSurfs (vlax-get aecProj "Surfaces")
    	aecSurf	 (vlax-get aecSurfs "Currentsurface")
    	aecUtil	 (vlax-get (vlax-get aecApp "activedocument") "Utility")
      (if (and (= aecSurf "")
    	   (> (vlax-get aecSurfs "count") 0)
        (setq aecSurf (vlax-get (vlax-invoke aecSurfs "item" 0) "name"))
      (if (= aecSurf "")
        (princ
          "\nNo surfaces defined, try again after creating a surface."
        (progn
          (setq aecSurf (vlax-invoke aecSurfs "item" aecSurf))
          (while (setq
    	       pt# (getpoint "\nPoint to label on the current surface: ")
    	(setq e-n (vlax-invoke aecutil "xytoeastnorth" pt#))
    	(setq selev (vlax-invoke
    		      aecSurf
    		      "getelevation"
    		      (car e-n)
    		      (cadr e-n)
    	;;Insert your block insertion and attribute setting here
    	(setq blk (vlax-invoke space 'insertblock pt# bname 1.0 1.0 1.0 0.0))
    	(setq att (car (vlax-invoke blk 'getattributes)))
    	(vla-put-textstring att (rtos selev 2 2))
    	;(princ (strcat "\nElevation at point = " (rtos selev)))
      (*error* nil)
    ;;;make as many of these as you need, this is for the SPOTL40 block
    (defun c:SPOTL (/ bname)
      (setq bname "sptl40");;set the block name in this line
      (if (or (tblsearch "BLOCK" bname)
    	  (setq bname (findfile bname))
        (attsurf bname)
      (princ)
    2015-12
    Central Oregon
    591
    All other machines are also running some version of LDT (3 - 2007)? Could you post the results of the following 2 lines, run at the command line, from at least 2 of the problem computers?
    (getvar "acadver")
    (vlax-product-key)
    2015-09
    Springfield, MA
    491
    my pc
    Command: (getvar "acadver")
    "16.2s (LMS Tech)"
    Command: (vlax-product-key)
    "Software\\Autodesk\\AutoCAD\\R16.2\\ACAD-4008:409"
    pc1
    Command: (GETVAR"ACADVER")
    "16.2s (LMS Tech)"
    Command: (GETVAR"ACADVER")(VLAX-PRODUCT-KEY)
    pc2
    Command: (GETVAR "ACADVER")
    "16.2s (LMS Tech)"
    Command: (VLAX-PRODUCT-KEY)
    pc3
    "16.2s (LMS Tech)"
    2015-12
    Central Oregon
    591
    Hmm, I'm re-installing 2006 now to see if I can track this down......
    2015-09
    Springfield, MA
    491
    wicked odd. there must be something on my pc that is not on the others? or the lisp is not finding the blocks in the drawing? i don't even know what that error means.
  1. keep getting a "class not registered" error
    By architectural-designer in forum ACA General
    Last Post: 2007-10-13, 06:38 AM
  2. Replies: 1
    Last Post: 2006-11-08, 03:38 AM
  3. Replies: 1
    Last Post: 2005-11-15, 07:35 AM
  4. Replies: 3
    Last Post: 2005-10-11, 06:59 PM
