Hi i am currently working on a tower in revit for my firm. And i just wanted to start a topic based on what would be the most effecient way in modeling them. Currently the best way i have figured out how to model the tower, is
1) making the core walls with their furred out walls go all the way through the tower. The reason behind this is one big wall is probally takes less infomation than a single wall for every single level.
2) then creating partition walls for the room seperation/ hallway, for levels that have differnt layouts. For example the first two levels are totally differnt from the fourth level. And the fifth level the partition walls go up to level 49, because they have the same layout, and the last three levels have their own floor plan.
3) then creating groups for furnature and interior walls that seperate the rooms/bathroom/closet.
4) I have decided to use furnature familes that are not 3d, and only have a elevation, and plan profile. To cut done on file size...to make work flow more managable.
5) For the curtain wall. I think making them go floor by floor, and creating a group out of the typ curtain wall so if you change panel size or mullion placement on one floor it will automatically change on all levels.
6) For stairs using multistory stairs for the levels that have the same floor to floor height.
(have been having a bit of trouble with this...because the calculation seems to fall a fraction of distance off and it adds up when you go up 40 something levels.. If anyone had any suggestions please let me know.)\
These are some of the things i have been doing to work on the tower. I don't know what other people are doing, so please let me know...andy help would be nice.....
thanks,
O
