View Poll Results: Are you adding Dynamic Blocks to your block library?
Voters
78. You may not vote on this poll
  • Yes
    57 73.08%
  • No
    20 25.64%
  • I don't know what Dynamic Blocks are.
    1 1.28%
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Are you adding Dynamic Blocks to your block library?
    2003-11
    442
    Default Are you adding Dynamic Blocks to your block library?
    I just started to mess with dynamic blocks and really like what I see. I will be updating all of my piping blocks to DB's. Is everyone else doing this?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,449
    Default Re: Are you adding Dynamic Blocks to your block library?
    I've converted a few, but most are still non-dynamic. I have not found a lot of use out of them for civil work.
    2003-11
    Blue Springs, Mo.
    117
    Quote Originally Posted by Opie
    Diddo for Civil
    0,0,0 The Origin
    8,569
    So far, I don't see any point in using them for mechanical.
    John B
    All AUGI, all the time thomas.stright's Avatar
    2015-12
    Texas
    535
    I've been messing with them a bit, but we really don't use blocks at all.
    BIM/VDC Management Brian Myers's Avatar
    2003-02
    St Louis, Missouri
    1,817
    Personally I'd add Dynamic Blocks, but I doubt I'd update too many of my existing blocks unless I had a good reason (need) to do so....
    Brian Myers
    Jacobs: VDC Design Office Lead (BIM Leadership)
    Visit my LinkedIn Profile for more information.
    I could stop if I wanted to Ogre's Avatar
    2005-06
    In the end, Cauliflower is just albino Broccoli
    288
    I am not in the Civil industry, but rather the manufacturing...It is kind of different...I run the CAD department and create drawings for "instruction manuals" (more like details of the product we sell)...These IM's include a riser diagram...This is where Dynamic blocks have really increased production...These risers are similar to those on Arch. dwgs with a little more detail since we know what is being installed...
    I updated our blocks to dynamic and it has saved about 30 minutes each riser that we do...While some are not that complex, others take up quite a bit of space...Granted there are features that I am waiting for regarding dynamic blocks like multiple visibility parameters, but what we have save so much time...There is still some tweaking that I need to do, but for 90% of our jobs, they work wonders...
    2003-11
    442
    Ogre
    What do you mean by Multiple Visibility Parameters? Aren't there already visibility parameters built it to dynamic blocks?
    2005-06
    288
    Quote Originally Posted by boesiii
    Ogre
    Multiple visibility parameters will help if only a certain portion of the block changes...There is 1 visibility parameter allowed per dynamic block...If I have a 2 gang lighting control station and it could have any combonation of 6 controls, the total number of items in the visibility list would be 36 items long...If multiple visibility parameters were allowed, then you would just need 2 lists of 6 items instead of the 1 list with 36 items...
    I hope this makes sense...I work in the Arch & Theatrical lighting controls industry and the example above is the best I could do...If this is not clear, please let me know your field and I will try to think up something that you can relate to better...Thanks...
    2016-01
    Manchester,England, UK
    178
    I have had to put No on the poll because I dont know much about it but if i can find the time to look into how they work I would use Dynamic Blocks.
  1. Adding Attributes to Dynamic Blocks and getting them to display
    By james.126519 in forum Dynamic Blocks - Technical
    Last Post: 2007-09-19, 01:40 PM
  2. Replies: 7
    Last Post: 2007-02-05, 01:11 PM
  3. Dynamic Blocks in a master library drawing, is it the best method
    By rgorman in forum Dynamic Blocks - Technical
    Last Post: 2006-12-08, 04:41 PM
  4. dynamic block library
    By jamie.casile80054 in forum Dynamic Blocks - Technical
    Last Post: 2005-08-23, 11:19 PM
