Results 1 to 6 of 6
Thread: Unable to select OLE Objects
    Member jrd.chapman's Avatar
    Ontario, Canada
    49
    Default Unable to select OLE Objects
    I have a user that is working with a drawing from an outside source that seems to have OLE objects embedded in it. The objects appear in the drawing but are not selectable, meaning, I can't even get the "move" cursor to show up when dragging crosshairs over the object in order to right-click and put a checkmark beside "Selectable".
    Anyone have any suggestions about how to make these objects selectable again?
    Thanks in advance
    2015-12
    Arizona
    2,337
    Default Re: Unable to select OLE Objects
    right-click over it and chose selectable
    Ontario, Canada
    49
    Right-clicking over it acts as if it is not there, i.e., a right-click just repeats the last command, or brings up the generic CAD shortcut menu depending on how you have right-click customization set up.
    Active Member chadwickt's Avatar
    2015-12
    84
    Is there any chance that the OLE Object was inserted on a locked layer?
    You might try unlocking some layers to see if it becomes selectable...
    Hope that helps
    -Tracy
    13,654
    Quote Originally Posted by chippychaps
    Hi
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section...
    ID: TS64541 - Unable to select inserted OLE object to remove or edit it
    Have a good one, Mike
    Ontario, Canada
    49
    Thanks to all who responded.
    Thanks especially to Mike Perry for directing me to that knowledge base article!!
    Take care!!
    John D. Chapman
  1. Unable to select objects
    By twollifur in forum Revit Architecture - General
    Last Post: 2011-06-29, 03:04 PM
  2. Unable to select multiple objects
    By theald in forum AutoCAD General
    Last Post: 2010-07-15, 10:24 PM
  3. Unable to select objects with elevation
    By ewhite in forum AutoCAD General
    Last Post: 2008-11-25, 04:15 AM
  4. Unable to select objects!!
    By Jason in forum Revit Architecture - General
    Last Post: 2005-08-26, 10:23 PM
  5. Unable to select objects via their Grips
    By spaynter in forum AutoCAD General
    Last Post: 2005-02-17, 06:09 PM
