Thread: Interior and Exterior doors
    2005-09
    Northern Virginia
    10
    Default Interior and Exterior doors
    I need to export Revit files to DWG and match client standards at the same time. Is there anyway in Revit to specify whether a door is interior or exterior and have it export to a layer depending on what type it is?
    All AUGI, all the time robert.manna's Avatar
    2005-05
    Boston
    777
    Default Re: Interior and Exterior doors
    You would need two different door families, with the geometry set to different subcategories. You can then map subcategories to seperate levels.
    HTH,
    -R
    2005-09
    Northern Virginia
    10
    These subcategories would be defined in the family right?
    2005-05
    Boston
    777
    Yes, you need to define the subcats in the family, so that that geometry in the family can be assigned to the subcats. If you name a subcat exactly the same in every family, for instance "Hardware", and you use it 5 different doro families, in a project the subcat "Hardware" will only show up once. However, if in one family you name it "hardware" then in a project you will have two subcats, "Hardware" & "hardware".
    HTH,
    -R
    2005-09
    Northern Virginia
    10
    I think I got it now. Thanks for your help.
    Matt
  1. Replies: 4
    Last Post: 2011-08-24, 06:40 PM
  2. Interior-Exterior Scenes
    By dibujante.a in forum Revit - Rendering
    Last Post: 2010-05-23, 01:51 AM
  3. Very bright exterior when rendering interior
    By Eric Stewart in forum Revit - Rendering
    Last Post: 2008-07-02, 02:47 PM
  4. wall types by interior & exterior
    By ggriffin in forum Revit Architecture - General
    Last Post: 2008-02-29, 04:47 PM
