i am at a loss. what is the difference between polar and linear params/actions? i looked through the help file and didnt find anything i could wrap my brain around.
danke.
danke.
Think "Polar" Array vs. the regular one as compared to the Polar parameter vs. Linear parameter.Originally Posted by Chad_C
what the polar option allows you to do is simultaniously stretch and rotate all in one action. the multistep way is to have both linear parameter and a rotate parameter.
S&D DB Sharing Forum
That being said, it's also a more complex parameter and requires a bit more thought on behalf of the user. The grip is different; it's a box instead of an arrow marker.Originally Posted by Chris.N
It is, however, a great option to go with if you are stretching and rotating. less work on behalf of the caddie using it, IMHO. And it's one less thing to worry about in DB creation.
[SIGPIC][/SIGPIC]
Return of the Cowbell
Keep your eye on the command line....after you select objects to stretch you are asked for objects to rotate....polar can be tricky
as long as you remember that it always asks you for objects to stretch FIRST and then objects to rotate SECOND, it's not that bad. The harder part comes in knowing WHAT to include and what to exclude. That's the rub. But trial and error always works, and if you're THAT stuck, you can always post it on here and we'll give ya a nudge in the right direction.Originally Posted by r424andy
[SIGPIC][/SIGPIC]
Believe you me...I cursed polar the first few times i tried to use it...now its not as bad
I hear ya. I did the same thing when I first used it.Originally Posted by r424andy
[SIGPIC][/SIGPIC]
i got you all beat, i still curse polar stretch... it's the classic 'love-hate' relationship...Originally Posted by max.sabre
it's a competition???Originally Posted by Chris.N
[SIGPIC][/SIGPIC]
