Results 1 to 10 of 15
Thread: Scale drawing from metric to english
    2006-10
    2
    Default Scale drawing from metric to english
    I recieved a drawing that was drawn in metric and I need to scale it and convert it to architectural. Can this be done and how.
    Thanks
    2006-10
    2
    Default Re: Scale drawing from metric to english
    Nevermind i figured it out. In case anyone else has this problem i did it by drawing a line that was 25.4mm long then changed my units to architectural and drew a line 1" long. selected all to scale and refeerenced the drawing the legnth of the 1" line and brought it to the length of the metric line. From there you have a drawing thwat is 1 to 1 and go from there.
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Thanks for posting your solution. To my knowledge there's no way to do what you wanted to do originally without using the SCALE command in some way. I deal with this, too, a lot, so I keep an eye out for suggestions.
    150700
    3,439
    Quote Originally Posted by andycrox
    You simply could have typed Scale, selected all, typed R at the command line, and the typed 25.4 for the first distance and 1 for the second distance - no need to draw lines.
    Active Member Cadtharsis's Avatar
    2006-02
    Pi World. It's not what I was thinking. :(
    90
    TIP: I find that the ALIGN command allows you to do the same thing as SCALE, and faster.
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Quote Originally Posted by Maverick91
    Starting in 2006, this is all relatively automatic if you use INSUNITS properly. Make sure INSUNITS is set correctly in each drawing. If you've been doing all your work with INSUNITS=0 ("Unitless"), you may want to change your habits and start using INSUNITS correctly...
    For example, say your source has 1 Drawing Unit = 1 Meter, and you want it in a drawing where 1 DU = 1 Inch. Make sure INSUNITS is set to "Meters" in your source drawing. Then create or open a drawing with INSUNITS = "Inches". INSERT your source drawing as a block. The conversion will happen automatically, although you may have to move/rotate the inserted block to get it into the correct horizontal placement. The easiest way is to make sure you don't explode the block until you know it is placed correctly.
    A word of warning: Autodesk screwed up with the units. The "Feet" units are really "International Feet". If you're in a state (like Colorado) that uses US Survey Feet instead of International Feet, the conversion won't be quite right...
    Of course, in most situations, the difference between "International Feet" and "US Survey Feet" doesn't matter. But in some cases, the difference does matter, so it's up to the user to pay attention. Autocad does have a "Parsecs" unit, however... Guess there's more Autocad users out there who use Parsecs than there are Autocad users who use US Survey Feet...
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Quote Originally Posted by tburns
    Tip:
    You could always memorize these values as I have. When scaling something up to metric, type 25.4
    When scaling something down to Architectural, type 0.0393700787402
    Easy as PIE.
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    150700
    3,439
    Quote Originally Posted by max.sabre
    Tip:
    Easy as PIE.
    Yea, me too, I do it so frequently...
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Thanks
    Have you looked at the system variables discussed in this AutoCAD FAQ thread, "Blocks, Images or Xrefs not inserting correctly?"?
    0,0,0 The Origin
    8,570
    When scaling something down to Architectural, type 0.0393700787402.
    10/254 is easier to remember.
  1. Metric Drawing Scale
    By Joy_1611 in forum AutoCAD General
    Last Post: 2011-10-18, 08:50 PM
  2. English to Metric
    By rvthor in forum MDT - General
    Last Post: 2008-07-18, 03:30 PM
  3. Area in metric from English units drawing
    By robert.1.hall72202 in forum AutoLISP
    Last Post: 2006-01-30, 08:58 PM
  4. AEC dims showing metric in an english drawing
    By jonesb33145 in forum ACA General
    Last Post: 2005-03-28, 06:49 PM
  5. tranfer drawing scale from imperial to metric
    By new@revit in forum Revit Architecture - General
    Last Post: 2004-02-17, 05:38 PM
