Thread: Shortcut Menus in partial cui's
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Shortcut Menus in partial cui's
    My scenario is as follows. I have an office of over 150 users with about 15 teams each. Most use a default profile and will be using ADT 2006. Most use the profile to run ADT as AutoCAD, however a few teams use the ADT profile - each of which has their own workspace. Some teams have custom content and commands for their team. This will require a seperate profile and workspace for each custom build (yes a seperate profile for each team since different teams point to different content locations).
    In my infinite lazyness I thought it would be best to use one menu setup for all the different profiles and then simply use workspaces/profiles to control what is active and being used. However it would seem that when I use the ADT.cui as the Enterprise with the autocad, express tools and other *.cui files loaded as partial *.cui's in the ADT.cui that the Shortcut Menus for AutoCAD are disabled even when using an AutoCAD workspace/profile. Am I correct in my assesment that in order for the Shortcut Menus to work properly, they must be part of the menu that is fully loaded?
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Shortcut Menus in partial cui's
    IIRC, the 2006 CUI had an issue where all shortcut menus had to be placed in one CUI file, I can't remember if it was the first or last. Any shortcut menus in any other CUI were ignored. There were lots of other issues, too. The CUI is extremely problematic even in 2007, and it was nearly unusable in 2006.
    BTW, profiles and workspaces are unrelated. Workspaces exist in CUI files. Profiles mainly contain paths and various other items from the OPTIONS. You can use Profiles to control which CUI files get loaded, but Workspaces have no direct connection to Profiles. A single CUI file can have multiple Workspaces in it.
    2015-12
    4,730
    Quote Originally Posted by richards.64879
    That's what I figured the case was. Buggers. Shoulda known it wouldn't have been that easy.
    I realize there is no direct link between them in a programing sense. I was thinking more along the lines of an association since the profile will load the proper workspace. There is however a connection when you are working with the *.aws file associated with the profile which is different from the multitudes of workspaces I'll end up with for my multitudes of teams.
    Earth
    9,803
    When you say "shortcut menu" are you talking about POP0 or the POP50? menus
    POP0 can be in any CUI file in all releases.
    R.K. McSwain | CAD Panacea |
    13,656
    <SNIP>
    Hi
    Sorry, that statement is not quite true in relationship to AutoCAD 2006 ( and vertical based products )... take a look at TS1056204 found HERE.
    Have a good one, Mike
  1. Loading Partial Menus
    By visualmatrix in forum AutoCAD Customization
    Last Post: 2011-07-15, 12:03 PM
  2. Replies: 5
    Last Post: 2006-02-02, 04:00 PM
  3. Position Pull Down Menus - Partial CUI
    By gsmith.29521 in forum AutoCAD CUI Menus
    Last Post: 2005-11-04, 05:43 PM
  4. Using Partial Menus in CUI - Easier or Harder?
    By Steve Johnson in forum AutoCAD CUI Menus
    Last Post: 2005-07-27, 05:50 PM
