Results 1 to 6 of 6
Thread: Modified Quick Leader command, how to get back original options
    2005-12
    Columbus, OH
    158
    Question Modified Quick Leader command, how to get back original options
    I modified the qleader command a little to set a width for the mtext based on dimscale and the code I wrote works great, but I don't have the option now, if I'd like to change any of the settings. So my question is how would I get that option back into my command.
    This is was I put together:
    (defun C:QL ()
    	(setq PT1 (getpoint "\nSelect First point: "))
    	(setq PT2 (getpoint pt1 "\nSelect Second point: "))
    	(setq MTW (* 1.0 (getvar "dimscale")))
    	(COMMAND "_QLEADER" PT1 PT2 "" MTW "")
    [ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]
    Last edited by Opie; 2006-10-09 at 06:07 PM. Reason: [CODE] tags added, see Moderator Action
    2003-11
    277
    Default Re: Modified Quick Leader command, how to get back original options
    Hi mhannan.100562,
    Do you mean like this,I'm not sure as you want
    (defun c:ql (/ pt1 pt2 mtw)
      (while
        (setq pt1 (getpoint "\nSelect first point: "))
        (setq pt2 (getpoint pt1 "\nSselect second point: "))
        (setq mtw (* 1.0 (getvar "dimscale")))
        (command "_qleader" pt1 pt2 "" mtw "")
      (princ)
    Quote Originally Posted by mhannan.100562
    (defun C:QL ()
    2002-12
    10
    If these that you want ?
    (defun C:QL ()
      (if (setq PT1 (getpoint "\nSelect First point:, [Enter for option] "))
        (progn
        (command "_qleader")
      (princ)
    2005-12
    Columbus, OH
    158
    Smile Re: Modified Quick Leader command, how to get back original options
    This is more along the lines of what I'm looking for, the only thing you have to hit enter twice now to get to the settings menu, and it kicks you out of the command.
    What I really would like is a system variable for the width of Mtext, but I can't seem to find one, but if I could hit a enter and get to the settings menu and then stay in the command that would be nice.
    Quote Originally Posted by mengseng
    (defun C:QL ()
      (if (setq PT1 (getpoint "nSelect First point:, [Enter for option] "))
        (progn
          (setq PT2 (getpoint pt1 "nSelect Second point: "))
      (princ)
    Member TobyKanoby's Avatar
    2006-06
    25
    Not sure if 0 for mtext width works better. Here is my try at it.
    TK
    (defun c:QL ()
      (initget 128);allow arbitrary entry
      (setq pt1 (getpoint "\nSpecify first leader point, or [Settings] <Settings>: "))
      (if (= (type pt1) 'LIST)
       (progn
        (setq pt2 (getpoint pt1 "\nSpecify next point: "))
        ;(setq mtw (getvar "dimscale"))
        (setq mtw 0);this also works
       (progn
        (if (member pt1 (list nil "S" "s"))
         (progn
          (command "_qleader" "s" ^c)
          (c:QL)
         (progn
          (princ "\nInvalid Input.")
          (c:QL)
     (princ)
    2005-12
    Columbus, OH
    158
    Thumbs up Re: Modified Quick Leader command, how to get back original options
    This is what I was looking for THANK YOU. I did change the mtext width setting back to what I was using. We like to have notes with word wrapping so we can modify the how many lines there are in the note without putting a hard return in the note.
    Thanks again for everyone help on this, my users also thank you.
    Quote Originally Posted by TobyKanoby
    TK
    (defun c:QL ()
      (setq pt1 (getpoint "nSpecify first leader point, or [Settings] <Settings>: "))
       (progn
        (setq pt2 (getpoint pt1 "nSpecify next point: "))
       (progn
         (progn
          (c:QL)
         (progn
          (princ "nInvalid Input.")
          (c:QL)
     (princ)
  1. Design Options - How do I revert to original model?
    By rtaube in forum Revit Architecture - General
    Last Post: 2012-02-09, 11:50 PM
  2. User profile reverts back to original
    By jenniferchavez in forum AutoCAD Civil 3D - General
    Last Post: 2011-05-31, 09:10 PM
  3. Copied Leader lines point back to original geometry
    By trud1966 in forum AutoCAD General
    Last Post: 2007-05-29, 01:03 PM
  4. Replies: 8
    Last Post: 2006-10-28, 09:47 PM
  5. Visretain to hold only layers modified from original xref
    Last Post: 2006-02-28, 08:37 PM
