Originally Posted by
camncad
2. I launch Batchplt following the usual steps as shown top two pictures. The second one shows that Batchplot failed.
3. I use plot command and plot one drawing at a time as shown the 3rd & 4th picture. As you may notice in the 4th picture, the page setup shows "none". Apparently, the conversion doesn't include the page setup that I have specified during the migration process. Am I missing something?
B- PUBLISH
After setting up the Page setup, the Batch Plot process to MSPACE-PDF is flawless and without any particular problem.
For some reason the Migration tools doesn't include the Page Setup that I've specified (I open the converted drawing and the Page setup isn't there), therefore I have to spend a few more mouse clicks (Select All the drawing - Click on Drop down box - Select Import - Browse to the directory where template *.DWT located - Select the Template - Select the appopriate Page Setup) to import the Page Setup manually. Is there a better way of making this process just a click or two away?
