Results 1 to 8 of 8
Thread: Delete key doesn't work!
    2005-08
    12
    Default Delete key doesn't work!
    Something has happened on one of my coworker's computer and his delete key does not work in AutoCAD (2005). His delete key works in other programs like Word and Outlook. Is there a system variable somewhere that may have been messed up? Any ideas how to fix this?
    Thanks
    Ian
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Delete key doesn't work!
    Hi Ian,
    Is the PICKFIRST system variable set to 1?
    HTH
    2005-08
    12
    It was set to 0. We changed it to 1 and it works fine. Thanks for the quick help!
    Ian
    Lost
    1,473
    You're welcome.
    2006-10
    Talking Re: Delete key doesn't work!
    I'm new to AUGI but this message alone was worth the (free) price of admission.
    I was doing a drawing and one minute delete, ctrl-x, and double click for properties worked. Then the next minute it didn't. Thanks for the information. You saved me from a lot of annoyance.
    -Jason
    Lost
    1,473
    Quote Originally Posted by jpatz
    -Jason
    I'm glad it helped you out. Welcome to AUGI
    2004-07
    Detroit Michigan
    2,508
    For someone just browsing this post............
    What is the pickfirst variable all about?
    150700
    3,439
    Quote Originally Posted by Robert.Hall
    From Help
    Type: Integer
    Saved in: Registry
    Initial value: 1
    Controls whether you select objects before (noun-verb selection) or after you issue a command.
    0 Turns off PICKFIRST; you select objects after you issue a command
    1 Turns on PICKFIRST; you select objects before you issue a command
  1. 2014: Delete Key doesn't work on my Mac Book Pro in AutoCAD 2014
    By LemonTree in forum AutoCAD for Mac General
    Last Post: 2017-02-18, 06:28 AM
  2. 2014: Delete Key doesn't work on my Mac Book Pro in AutoCAD 2014
    By LemonTree in forum AutoCAD General
    Last Post: 2013-11-15, 03:04 PM
  3. My delete key doesn't work in Autocad
    By mdaigr2 in forum AutoCAD General
    Last Post: 2013-08-21, 12:43 AM
  4. DYN doesn't work
    By geohutto520336 in forum AutoCAD LT - General
    Last Post: 2012-02-04, 08:28 PM
  5. Specify New Work Plane - doesn't work?
    By bnelson.188587 in forum Revit Architecture - General
    Last Post: 2008-07-24, 04:50 PM
