In AutoCAD LT 2004, the location of some of your customized files has changed. Reasons for the file location change include the following:
- Power user rights on a workstation. AutoCAD LT 2004 supports running AutoCAD LT as a limited-rights user. Part of this work requires customized support files to be moved from C:\Program Files\AutoCAD LT 2004 to the user's profile folder.
- Roaming profiles. AutoCAD LT 2004 supports roaming profiles, which allow you to log on to any computer within the network and retain your user settings. Some files, such as your personal settings and documents, follow you from computer to computer, while other files, such as templates (including Publish to Web templates) and texture maps, reside on your system and cannot be moved.
If roaming profiles are enabled on your network, your roamable files are located in your \application data\Autodesk\AutoCAD LT 2004 folder, and your non-roamable files are located in the \Local Settings\Autodesk\ AutoCAD LT 2004 folder.
Note In some operating systems, the folders that are located under your profile are hidden by default. To view these files, you may need to turn on hidden files. See Microsoft® Windows Explorer Help to learn how to turn on hidden files for your operating system.
