Hi Alls,
here my code to display slide,but I cannot solve this problem to display alls slide,this program only able display one type ,ie "Angle Bars", and for Channel and H Beam it cannot display.
Hi Alls,
Here slide file in attach file
Rename all library of slides (delete a point from names of files)!Originally Posted by Adesu
For example:
Hbeam 400x400x13.0x21.sld
Hbeam 400x400x13_0x21.sld
Hi elpanov,
I just rename as your suggest,and tested it,but result same as old program.
Originally Posted by elpanov
In the program too it is necessary to rename.Originally Posted by Adesu
I have checked up, for me works!Code:((= data_hbtyp 9)(setq vsld \"Hbeam 400x400x13_0x21\")))
Hi elpanov,
It's sound good info I surprise,I would rename it,wait for feed back,thanks.
Now, for you works?Originally Posted by Adesu
Hi elpanov,
I just tested it's OK for H Beam,but not yet for Channel (?).
Originally Posted by AdesuCode:((= data_chtyp 0)(setq vsld \"60x30x10x1.6\")) =>> ((= data_chtyp 0)(setq vsld \"Channel 60x30x10x1_6\"))Code:Channel 60x30x10x1.6.sld =>> Channel 60x30x10x1_6.sld
Hi elpanov,
yes that code need "Channel",and tested it's OK =>"THANKS A LOT"
but I only able display 3 slides for fouth it still cannot.
