Thread: Plumbing Fixture
    I could stop if I wanted to nsinha73's Avatar
    2006-09
    CA
    461
    Default Plumbing Fixture
    I am trying to create a plumbing fixture. When placed, it will hide the tiles or patterns beneath itself. In family editor mode, I cannot see any region fills tool (Wanna use the solid region) What is the walk-around suggested?
    Thanks
    It is much easier to be an Obstacle in Revit then a Resource.
    All AUGI, all the time robert.manna's Avatar
    2005-05
    Boston
    777
    Default Re: Plumbing Fixture
    If you want to have a filled region in a family you will need to nest a detail component into the family. Detail components can contain filled regions.
    -R
    I could stop if I wanted to raddis's Avatar
    2015-12
    208
    Try the attached.
    The trick is a vertical line as explained by Aaron Rumple to make it 2.5D.
    I still don't have the toilet paper holders or the 3D toilet in yet AND it is already 1mb in size (have to figure out a way to slim down).
    It is wall hosted so you need a wall to place it. There are toggles for the grab bars, lots of nested families and fills, but ut works, I think.
    Regards,
    Reid M. Addis
    Registered Architect
    Addis Computer Consultants
    330 Bryn Mawr Avenue
    Bala Cynwyd, PA 19004
    Cell. 610-996-9666
    email: raddis@addiscomputer.com
  1. 2014: Plumbing Fixture Counts
    By kim579708 in forum Revit Architecture - General
    Last Post: 2015-04-17, 11:24 PM
  2. 2011: Plumbing Fixture
    By jamie santiago in forum Revit Architecture - General
    Last Post: 2011-09-29, 01:26 PM
  3. Plumbing Fixture Heights
    By nubrun.188780 in forum Revit MEP - General
    Last Post: 2009-07-23, 02:27 PM
  4. Plumbing Fixture
    By sjsl in forum Revit Architecture - General
    Last Post: 2008-04-10, 03:31 PM
  5. 2D plumbing fixture - behaves like 3D
    By Martin P in forum Revit Architecture - Families
    Last Post: 2004-07-21, 02:22 PM
