Results 1 to 6 of 6
Thread: Display problems
    Active Member h.jobe's Avatar
    2005-11
    Turlock, CA
    97
    Default Display problems
    Hi
    Does anyone know what might make a view drawing look different from the source drawing, even when both drawings are using the same display representation?
    In the original drawing the walls display correctly, but in the view drawing, the walls entirely disappear. I copied and pasted the display rep to make sure that both drawings have exactly the same rep. It's not that the walls aren't there, either, because they show up fine in other reps. All the necessary layers are all turned on. I'm having trouble figuring this out - thanks in advance for any help!
    All AUGI, all the time Avatart's Avatar
    2004-06
    Upsidedown in dreamtown
    928
    Default Re: Display problems
    The first thing that leaps to my mind (such as it is) is the cut planes, are your walls being cut below their lowest part in the view drawing. Sounds like you are doing all the right things with the display reps, I assume that the walls are Xreffed in from an Architectural file and the Xref is loaded (sometimes it is the simplest things that trip us up)?
    2005-11
    Turlock, CA
    97
    Perfect! I think the problem was that this is the second floor - the view drawing wasn't adjusted to the correct level. Thanks for your help!
    2002-09
    Madison, WI
    5,688
    There is an ADT course Available in the archive section for ABS display theams that you may want to check out.
    All AUGI, all the time kyle.bernhardt's Avatar
    2005-10
    Inside the Factory
    705
    Smile Re: Display problems
    I also made a video about display thru xrefs, check it out.
    Cheers,
    Kyle B
    2005-11
    Turlock, CA
    97
    Nicely done! Thank you!
  1. 2014: Display Problems
    By barathd in forum Revit - Platform
    Last Post: 2014-01-13, 08:44 PM
  2. Problems with the display of Objects.
    By IgS in forum NavisWorks - General
    Last Post: 2009-07-15, 07:52 AM
  3. Display problems
    By skivell in forum AutoCAD General
    Last Post: 2009-07-15, 05:44 AM
  4. Phase Display problems
    By Isaacarus in forum Revit Architecture - General
    Last Post: 2005-10-08, 10:48 AM
