Thread: Interior Elevation Tag Issue
    Active Member pcore's Avatar
    2006-08
    53
    Default Interior Elevation Tag Issue
    Several issues actually.
    Is there a way to make the circle around the A601 smaller?
    Also, is there a way to remove the "5GROUP STUDY 148" and still name the view on the A601 sheet?
    Barring that, is there a way to keep the text from obscuring the walls and doors etc. with a white box?
    Patrick
    2004-07
    Lenexa, Kansas
    98
    Default Re: Interior Elevation Tag Issue
    Go to (Settings>VIew Tags>Elevation Tag) You can change everything except the text background
    Is there a way to make the circle around the A601 smaller?<Change the width
    Also, is there a way to remove the "5GROUP STUDY 148" and still name the view on the A601 sheet?< uncheck (Show View Name)
    Barring that, is there a way to keep the text from obscuring the walls and doors etc. with a white box?< I don't see an option for the text background
    2004-05
    77
    Go to "Settings,... View Tags.. Elevation tags..."
    Choose 1/2" Circle (or whatever the tag is called).
    uncheck the box next to "Show View Name".
    Also I think you can change the circle size there.
    John Tobin
    2006-08
    53
    Great, thanks!
  1. 2012: Interior Elevation Tag
    By fputnam in forum Revit Architecture - General
    Last Post: 2011-12-30, 04:11 PM
  2. Interior elevation key
    By mrdavie in forum Revit Architecture - General
    Last Post: 2011-04-06, 08:44 PM
  3. Interior and Exterior Elevation Tag Issue
    By pashley in forum Revit Architecture - General
    Last Post: 2008-11-26, 06:25 PM
  4. interior elevation tag
    By pcore in forum Revit Architecture - General
    Last Post: 2007-01-08, 03:32 PM
  5. Interior Elevation Tag
    By .chad in forum Dynamic Blocks - Technical
    Last Post: 2006-08-09, 08:35 PM
