Thread: I don't have an acaddoc.lsp file. Can I put my code into acad2000doc.lsp?
    2006-01
    Question I don't have an acaddoc.lsp file. Can I put my code into acad2000doc.lsp?
    I attended a cad camp yesterday, and I am trying to write my own lisp routines. I don't have an acaddoc.lsp file. Can I put my code into acad2000doc.lsp?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,185
    Default Re: I don't have an acaddoc.lsp file. Can I put my code into acad2000doc.lsp?
    I, and others, would not recommend it. The ACADDOC.LSP and ACAD.LSP files are user created. You would then place these files in a directory that is listed in your Support Files Search Path. AutoCAD will automatically load the first ones found.
    I could stop if I wanted to pnorman's Avatar
    2005-02
    Calgary
    203
    Use Notepad or Wordpad to create a new file called acaddoc.lsp
    Save as "text document"
    Or better still, from the AutoCAD command line type "vlide" then go File/New and then "Save as"
    Do not use acad####doc.lsp!!
    Regards
    Phill
    Earth
    9,831
    You can put your code in there, but expect it to be lost at some point. As the others have said, "acaddoc.lsp" is a user file. Create and maintain it yourself.
    See these links for more info:
    http://support.autodesk.com/Getdoc.asp?ID=TS21336
    http://support.autodesk.com/getdoc.asp?ID=TS28079
    http://support.autodesk.com/getdoc.asp?ID=TS43235
    R.K. McSwain | CAD Panacea |
  1. set up acaddoc.lsp to reset log file path
    By cuckoo22 in forum AutoLISP
    Last Post: 2010-05-05, 01:37 PM
  2. How to open a file with a lisp code?
    By ccatinean in forum AutoLISP
    Last Post: 2009-01-19, 01:08 PM
  3. Replies: 10
    Last Post: 2007-10-09, 01:11 PM
  4. Convert AutoCAD DWG file to G-Code
    By num1husker in forum AutoCAD General
    Last Post: 2007-03-09, 09:28 PM
