Thread: When using LAST or PREVIOUS I only get the last Object that is in my viewing window
    2015-12
    385
    Default When using LAST or PREVIOUS I only get the last Object that is in my viewing window
    Hello all,
    When in AutoCAD (ACAD 2004 for now), I noticed that when I use the "last" or "previous" I only get the last onject that is in my viewing window. Is there a variable or anything that I can set to make Acad look for the last object in the entire drawing,in my vowing window or not?
    Thank you all in advance,
    Andre
    0,0,0 The Origin
    8,570
    Default Re: When using LAST or PREVIOUS I only get the last Object that is in my viewing window
    "Last" has always been interpreted as "last-created object currently visible on screen" - until A2007 when it was changed to "last object".
    2005-07
    2,356
    But previous is last object selected (not created), and it shouldn't matter whether it is on screen or not.
    0,0,0 The Origin
    8,570
    "Previous" is a selection set that can contain anything from one object to the entire content of the current space and should always mean that.
  1. New Object Viewing
    By gsteffen642486 in forum ACA General
    Last Post: 2012-10-19, 04:41 PM
  2. 2011: Lost Control of Viewing 3D object
    By yusof.ghani in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-11-22, 03:02 AM
  3. 2012: Viewing Window Tags in Plan
    By StacyJennifer in forum Revit Architecture - General
    Last Post: 2011-09-16, 09:34 PM
  4. Viewing object XDATA in NavisWorks?
    By dgorsman in forum NavisWorks - General
    Last Post: 2009-01-07, 04:10 PM
