There are common nails located in the rough framing portion of your detail components. Here it is, it has all nail sizes so it's pretty useful. I also threw in an SDS screw, looks good. I have a bunch of simpson hardware too.
Josh
Josh
I am unable to get these into my section or elevation or detail views only in the drafting views. How come that is the case?
David
After dropping in to drafting view, I was able to copy/paste to detail view. Wonder if it is somewhere in the model?
Hi
I was searching for a pipe support clamp and bracket. i couldnt get that. accidently i see this so i thought may be you can help me with this. i have pipes ranging from 50 dia to 300 dia. so could you please tell me where can i get this?? basically i am looking for HILTI clamp and unistrut. hope you can help me.
Thanks and regards
You might want to post your request in the MEP forum as well with a hyperlink back to this thread. For myself, I created the unistrut profiles long ago, that I use in sweep as profiles when needed. I don't get into the clamps & other connections to often.
Cheers,
Jeff S.
THANK YOU. It is amazing how difficult it is to find a simple lag bolt drawing in 2D. Again thank you.
