Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Bolts Nuts Screws & Nails
  1. #11
    All AUGI, all the time ford347's Avatar
    2005-01
    Oroville, CA
    874
    Default Re: Bolts Nuts Screws & Nails
    There are common nails located in the rough framing portion of your detail components. Here it is, it has all nail sizes so it's pretty useful. I also threw in an SDS screw, looks good. I have a bunch of simpson hardware too.
    Josh
  2. #12
    I could stop if I wanted to david.metcalf's Avatar
    2004-01
    Hartford CT
    315
    I am unable to get these into my section or elevation or detail views only in the drafting views. How come that is the case?
    David
    After dropping in to drafting view, I was able to copy/paste to detail view. Wonder if it is somewhere in the model?
  3. #13
    2012-07
    Hi
    I was searching for a pipe support clamp and bracket. i couldnt get that. accidently i see this so i thought may be you can help me with this. i have pipes ranging from 50 dia to 300 dia. so could you please tell me where can i get this?? basically i am looking for HILTI clamp and unistrut. hope you can help me.
    Thanks and regards
  4. #14
    2015-11
    Madison, WI
    1,318
    Quote Originally Posted by sujeevtk187479 View Post
    You might want to post your request in the MEP forum as well with a hyperlink back to this thread. For myself, I created the unistrut profiles long ago, that I use in sweep as profiles when needed. I don't get into the clamps & other connections to often.
    Cheers,
    Jeff S.
  5. #15
    2020-05
    Quote Originally Posted by blads View Post
    Will these do... I can't remember where I got them from
    It brings very fond memories and sadness to see this great contribution by "uncle" Bill. Unfortunately, he's no longer with use. Rest in peace, mate!
    Warm regards from Southern California,
    Emmanuel A. Garcia
    Past AUGI President and Fellow Founding Director
  6. #16
    2022-09
    THANK YOU. It is amazing how difficult it is to find a simple lag bolt drawing in 2D. Again thank you.
  7. #17
    6,419
    If you can get one in 3D, just use the VIEWBASE command to get a 2D view of it. The FLATSHOT command may also work.
    LinkedIn
  1. Mass of nuts & bolts in Parts list
    By csawdy933916 in forum AutoCAD Mechanical - General
    Last Post: 2011-10-19, 12:22 AM
  2. Obtain 3D Parts - Phillip pan head screws, hex nuts, etc
    By jgh in forum AutoCAD 3D (2006 or below)
    Last Post: 2005-11-04, 06:18 PM
  3. Nuts, bolts etc
    By ita in forum Revit Architecture - Families
    Last Post: 2005-04-27, 05:14 AM
  4. Screws and bolts
    By tbedrich in forum AutoCAD General
    Last Post: 2004-10-26, 11:02 PM
