To bring up the layer dialog box takes forever and a day. Is there some features that I can disable to get it back up to speed? For a tool that is is used so much, it is really affecting my speed. Any suggestions are appreciated.
Hi
Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
ID: TS74036 - Layer Properties Manager loads slowly
Have a good one, Mike
argh, it was already set to zero and still slower than mollasis in December. Thx for the reply anyhow
once the drawing finally opens, open the layer manager and delete the
layer filters
Hi
Is the Layer Dialog Box slow to display for all drawings or just certain ones?
ps Am just leaving for the evening will catch up tomorrow if needed.
This did the trick, hit the button and BAM, there she is. Thanks bunches!Originally Posted by nhugley
I've found this usually takes a long time because of all the Layer Filters. Delete them.
