Doesn't a "customized.mnu" suppost te be recompiled automatically when modified after restarting Autocad?
maybe i must be clearer.
i have a additional mnu file.
each time a do a modification in that file i have to
menuload
unload
load
insert it into the menu...
shouldn't it be that when a mnu file is modified, it recompilated automatically when restarting autocad?
I am not sure about mnu, but mns should update
Hi Johan.
With the old system you would delete the equivalent mnx file to ensure that the mnu file was recompiled. I don't play with the cui so I'm not sure what the equivalent is. Erase the partial cui file would be the obvious answer but not necessarily the correct one.
johan,
You did not specify which version of AutoCAD you are requesting help on.
2006 and 2007 use a CUI for menu customization. If you want to update the CUI, you would need to edit the CUI file. It should automatically update in AutoCAD. If you are editing a MNU file for these versions, you would need to unload the equivalant CUI file and reload your newly edited MNU file.
For 2005 and older, I would think deleting the associated MNC file should have your MNU file recompiled. However, if I recall, the MNU would automatically recompile if it had a newer time stamp than the associated MNC file.
it's 2005
- if I recall, the MNU would automatically recompile if it had a newer time stamp than the associated MNC file -
that's not the case actually
deleting the compiled ones creates new ones...
thanks
It's been a while since I have messed with a MNU file.Originally Posted by johan d
Glad you got it to work.
Rather messing up the mnu file than the cui...Originally Posted by Opie
