Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Educational copy Plot Stamp
    100 Club moshira_hassan's Avatar
    2003-01
    133
    Default Educational copy Plot Stamp
    Hello people ......
    i got an dwg file that was created by an educational CAD Copy .... each time i try to polt this file i got an educational copy bold stamp on my output sheet .... and even when i copy any object from this file to anther file .. the educational copy stamp moves to my file .... any way i can get rid of this annoying bug ....
    0,0,0 The Origin
    8,570
    Default Re: Educational copy Plot Stamp
    EDU-scan from manusoft may help.
    13,656
    Hi
    The following threads may also offer some help / guidance on this matter...
    Educational stamp issues
    Educational plot stamps
    Produced by and Autodesk Educational Product
    Educational Plot Stamp
    Have a good one, Mike
    Earth
    9,803
    Quote Originally Posted by moshira_hassan
    Hello people ......
    It's not a "bug", it's it there to prevent commercial use of an educational copy of AutoCAD.
    Get rid of any drawings that have this stamp or it will spread like a virus (as you have seen).
    In the future, DO NOT use content created in the EDU version of AutoCAD.
    R.K. McSwain | CAD Panacea |
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    Quote Originally Posted by rkmcswain
    Yeah, I agree with this 100%. We also have this problem in the office that even if you are using a full licensed AutoCAD, and you copied just a single line from a drawing made in educational version, your drawings will also be 'contaminated' with the Educational plot stamp..FOREVER!!.
    2005-02
    Off the Grid
    560
    My friend found a workaround about this and I was surprised it worked.
    Save as a .dxf file. Open the dxf file and the Educational stamp is gone. Then save back to dwg if you want to. Tested in AutoCAD 2005.
    2005-06
    in the upper right corner
    3,504
    Talking Re: Educational copy Plot Stamp
    Quote Originally Posted by arshiel88
    I was going to say the same thing. We had an outside client provide us a drawing created from an "Educational" version, and no matter what we did we couldn't get rid of the plot stamp. We ended up using "export to AutoCAD, 2004 dxf" and resaved it as a .dwg and that fixed it. I don't know what that does to ADT or AEC objects if they exist but it was just line work and blocks for this situation.
    2007-03
    IRAN
    5
    Question Re: Educational copy Plot Stamp
    HI EVERYBODY
    HELP ME TO REMOVE THE Educational STAMP WHEN PLOTTING.THANKS
    0,0,0 The Origin
    8,570
    Hi.
    Just read the two posts above yours.
    Earth
    9,803
    Lightbulb Re: Educational copy Plot Stamp
    Quote Originally Posted by MILADNAZARI004
    HI EVERYBODY
    Quit using content created with educational versions of AutoCAD for commercial uses.
    That will solve it, guaranteed.
  1. Educational Plot Stamp detected
    By cskelton in forum AutoCAD General
    Last Post: 2008-07-08, 07:38 AM
  2. Educational Plot Stamp
    By bart.lydon in forum AutoCAD General
    Last Post: 2008-07-02, 04:37 PM
  3. Educational Product Plot Stamp:
    By rrufer in forum ACA General
    Last Post: 2008-07-02, 04:14 PM
  4. PLOT STAMP OR EDUCATIONAL PRODUCT?
    By shabanshah007 in forum AutoCAD Customization
    Last Post: 2008-07-02, 04:12 AM
  5. Autodesk Educational Plot Stamp, what is it.
    By sudhirkizhakoote in forum AutoCAD Plotting
    Last Post: 2005-10-12, 10:09 AM
