View Poll Results: Would you like an enhaced Sketchup/Autocad2007-like mass modeler ?
Voters
8. You may not vote on this poll
  • A must
    6 75.00%
  • Pretty usefull
    0 0%
  • So so
    1 12.50%
  • Not very usefull
    0 0%
  • Unusefull
    1 12.50%
Thread: Enhanced Sketchup/Autocad2007-like 3d Modeler
    2006-03
    54
    Default Enhanced Sketchup/Autocad2007-like 3d Modeler
    Revit modeler can produce lots of forms - nurbs and lofts are still missing.
    Revit can also manage lots of forms created in other modelers (Sketchup, Autocad2007, Rhino, etc.).
    The only problem is Revit is not handy at all to model any complex 3d forms.
    The temptation is great to import them, but let's face it, it's a pain.
    So, I'd like to have a more intuitive modeler like sketchup or just Autocad2007 which both are very good.
    Modeling in Revit is fastidious because you always have to refer to a 2D construction plane. In fact Revit has only 2D drawing tools that generate 3D objects. That make things very fastidious.
    I'd like to be able to:
    - draw 3d lines without getting a work plane that geometrically contains that line.
    - push/pull any face/edge/summit of a mass in any free or constraint direction like in Autocad2007 - that's really powerfull.
    - draw lines directly on one face of the model and they get part of the model, then you can push/pull them - very handy in sketchup.
    - select a work plane from 3 points.
    All AUGI, all the time AP23's Avatar
    2005-11
    530
    Default Re: Enhanced Sketchup/Autocad2007-like 3d Modeler
    This would be absolutely great, but I don't see it happening as Revit (according to my reseller) was primarily made for the "strong delivery" firm. However, i do see these tools being implemented in Revit Structure. Structural engineers need to be able to model all types of buildings delivered by all types architects. Arup uses both RS (for more traditional buildings) and Microstation (for anything else, see attachment).
  1. Bridge Modeler
    By rochdan in forum Español - AutoCAD Civil 3D
    Last Post: 2010-11-17, 04:05 PM
  2. problemas con autocad2007
    By FerCar66 in forum Español - AutoCAD / AutoCAD LT
    Last Post: 2007-04-10, 02:30 AM
  3. STEPIN and STEPOUT restored to AutoCAD2007?
    By CrazyMike in forum AutoCAD Mechanical - Wish List
    Last Post: 2007-02-08, 07:59 PM
  4. Which is your favorite 3D modeler?
    By arshiel88 in forum Software
    Last Post: 2007-01-26, 01:37 PM
  5. Is there an update for doctabs for use with AutoCAD2007 ?
    By pkennedy.71515 in forum AutoCAD General
    Last Post: 2006-12-04, 03:35 PM
