Thread: Layer names from lower to upper case
    7
    Default Layer names from lower to upper case
    Does anyone know of a way to change layer names from lower to upper case?
    13,656
    Default Re: Layer names from lower to upper case
    Hi
    Check out the following Submission # EX001244 by Peter Jamtgaard on the AUGI Exchange Page -
    AUGI Exchange Search Page
    Have a good one, Mike
    Turlock, CA
    6,374
    If you are just asking how to do a layer at a time within the layer dialog, you have to do it in two steps. If you just try to change the case, the os thinks it is the same spelling and doesn't accept it. Just delete or add a letter with the case change and click apply. Then correct the added or deleted letter. HTH. Oh...same thing applies to renaming files in Explorer.
    C:> ED WORKING....
  1. 2013: Sheet set manager text a mix of upper case & lower case
    By nextvkin in forum AutoCAD Sheet Set Manager
    Last Post: 2018-03-27, 09:26 PM
  2. force UPPER/lower case in text
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2012-09-13, 02:35 PM
  3. Replies: 3
    Last Post: 2007-01-09, 12:42 PM
  4. Upper/Lower case text
    By djn in forum Revit Architecture - General
    Last Post: 2007-01-05, 10:40 PM
  5. Changing from UPPER case to lower case
    By IamSnave in forum AutoCAD General
    Last Post: 2005-02-09, 10:30 PM
