Thread: In place door family won't tag
    Member steve.89614's Avatar
    2005-06
    Woodland Hills, CA
    17
    Default In place door family won't tag
    Hi All,
    I created an in place door family as it works with a curved wall. The problem I am having now is that the door will not accept a door tag. I checked the properties and the door has a type mark and A Mark #. The door does not have a family or a type name which is perhaps the problem.
    Any Ideas?
    Thank you,
    Steve Shkolnik
    All AUGI, all the time archjake's Avatar
    2003-07
    Tucson, AZ
    531
    Default Re: In place door family won't tag
    I've had a similar problem in the past. It turned out that it was being tagged, but the tag was way out of my screen. Eventually I found it and moved it to the correct location.
    Jake Boen, Architect
    www.InPlaceArchitecture.com
    www.BIMproductivity.com
    Tucson, Arizona
    2005-06
    Woodland Hills, CA
    17
    Thank you for your reply,
    I've looked all over the screen - I undid the crop region and zoomed to fit and don't see the tag any where. All the other doors in the project tag fine but the In place family doors will not tag. Is there a way to turn the "in place family door" into a family door so that it will have a name and type?
    I am guessing that the reason that the door will not generate a door tag is because it does not have a family name or type name.
    Thank you,
    Steve Shkolnik
    2003-07
    Tucson, AZ
    531
    You may want to check the family category to make sure that it is indeed a door.
    If you edit the in place door family you can copy the geometry out and paste it into the family editor.
    Because your door is in a curved wall and we don't have a template for a curved hosted door you may need to do this into a generic un-hosted family template first, and then change the category to be a door.
    Good luck.
    Tucson, Arizona
    2005-06
    Woodland Hills, CA
    17
    Thank you guys,
    I couldn't figure out the problem and re-built the door as a curtain wall door panel system which solved the problem.
  1. 2014: Door/window family, to create or just model in place
    By david_peterson in forum Revit Architecture - General
    Last Post: 2014-06-12, 09:38 PM
  2. 2013: Door Family - Frame Types - Door Schedule - Legend Component
    By bmaxwell143848 in forum Revit Architecture - Families
    Last Post: 2012-10-29, 01:45 AM
  3. Tagging an in-place door
    By davidthigpen in forum Revit Architecture - General
    Last Post: 2009-03-28, 12:17 AM
  4. Door in in-place Wall Family? Revit 9.0
    By pwilson.112560 in forum Revit Architecture - Families
    Last Post: 2007-06-28, 05:03 PM
  5. Place Doors/Windows within In-Place Family Categories
    By cdchristian in forum Revit Architecture - General
    Last Post: 2007-01-10, 02:12 PM
