Thread: Create Bezier Surfaces in AutoCAD 2006
    2006-11
    2
    Default Create Bezier Surfaces in AutoCAD 2006
    Hi there,
    I'm struggling a bit with 3D surfaces, specifically Bezier surfaces. I need to create a Bezier surface in Autocad (2006). Whilst I understand the theory and maths behind Bezier curves I can't find any help for actually making a simple Bezier surface/patch (16 points).
    At the moment the best I can come up with is just inputting a 4x4 3D mesh, setting the SURFTYPE to Bezier ( and inputting the points which can't be right?? Any help much appreciated.
    0,0,0 The Origin
    8,570
    Default Re: Create Bezier Surfaces in AutoCAD 2006
    If you set SURFTYPE after creating the mesh, it probably isn't working (I'm not sure, I haven't don't this for a while). Have you tried the "Smooth Surface" option of the PEDIT command?
    2006-11
    2
    Well you see I have to give a detailed example of the use of Bezier technique to define a simple curved surface.
    Just setting SURFTYPE to 8 and adding the 16 data points doesn't seem what was intended. Is there any other way of creating a Bezier surface, maybe using the defining equations or something?
    Thanks
    0,0,0 The Origin
    8,570
    Perhaps a coon's patch ? Uses EDGESURF.
    This uses four curves, each of which could be a Bezier curve. I don't have a clue what you might call the resultant surface.
  1. GD211-2P: Using 3D AutoCAD® Surfaces to Create Composite Solids
    By Autodesk University in forum General Design
    Last Post: 2013-05-06, 01:42 AM
  2. AutoCAD 2006 create custom linetypes with filled dots
    By j_lowery135943 in forum AutoCAD General
    Last Post: 2007-03-22, 11:10 AM
  3. Replies: 3
    Last Post: 2006-12-26, 03:59 AM
  4. AutoCAD LT 2006 - 'Create tool palette' doesn't work?
    By bosso in forum AutoCAD LT - General
    Last Post: 2006-08-13, 02:49 AM
  5. VB to Create Time Record in AutoCAD 2006
    By bill.98542 in forum VBA/COM Interop
    Last Post: 2006-02-03, 11:09 AM
