Thread: Get total length of selected Polylines
    2005-12
    10
    Question Get total length of selected Polylines
    I have a problem hopefully someone might have a workaround that i haven't thought of,here goes! I work for the city of Barcelos (Portugal) in the electrical department, After we conclude the drawing part, we have to sum up all the lighting units and cable that will be needed, for the units i make blocks out of them giving tem reference names (ex.. Dorus ) then use qselect to select the blocks and within seconds i get the sum of the blocks that exist in the drawing with that name,easy right, problem comes from the cable part, where i have to convert the lines into polylines then use the length command to get the length then write down on paper and at the end sum it all up to get the final count. I tried to use qselect but in the properties tab length just says "VARIES" . Is there a way to sum up all the polylines length values to reach a total value, whether it be by qselect, filter, all on the same layer, hell even programing a routine.If anyone can help, i´ll give my word that i´ll put a good word for you in heaven, unless of course i don´t get in but thats a whole new story. Thanks for listening.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Get total length of selected Polylines
    Have you tried Cadalyst.com? The August 1999 code list has a polyline length routine.
    13,656
    Hi
    If need be, the following forum links offer additional help on this subject...
    RE: Total polyline length
    LISP to get total length including ARC, Pline & lines?
    Have a good one, Mike
    2005-12
    10
    Smile Re: Get total length of selected Polylines
    Thank you Opie, Thank you Mike, you can count on my vote if you want to run for president! but seriously thanks alot for the help.
    Earth
    9,805
    Quote Originally Posted by roygoncalves
    Sure, grab TLEN.LSP from http://www.turvill.com/t2/free_stuff/index.htm
    R.K. McSwain | CAD Panacea |
  1. Lisp for Total Length of Polylines
    By issabhazboun708277 in forum AutoLISP
    Last Post: 2015-09-08, 03:56 PM
  2. Polylines: total area and length
    Last Post: 2015-05-24, 10:44 AM
  3. Total Length of Polylines
    By vijaybaskergundla in forum AutoLISP
    Last Post: 2015-04-30, 04:29 PM
  4. Polylines: total area and length
    Last Post: 2014-01-29, 05:16 AM
  5. Polylines and Total Length
    Last Post: 2012-06-13, 08:10 PM
