Thread: Non-existant objects?
    2001-10
    Waukegan, IL
    52
    Default Non-existant objects?
    I get the following message (or some reasonable facsimile thereof) then I open certain drawings:
    "AutoCAD has not found an object enabler on the Autodesk website for AecCivilBase"
    I don't know of any objects inserted from AECCivilBase. There are no proxy images showing. What can I do to strip the drawing of whatever is calling up AECCivilBase?
    2001-10
    Waukegan, IL
    52
    Default Re: Non-existant objects?
    Sorry, ADT 2006, windows XP pro with Pinball shut off.
    Time Lord Steve_Bennett's Avatar
    far, far, far away...
    4,724
    type -PURGE and choose the option to purge RegApps. This is not covered if you choose the ALL option.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2001-10
    Waukegan, IL
    52
    Thanks. What IS all this?
    Purge registered application "30DE"? <N> y
    Purge registered application "30D9"? <N> y
    Purge registered application "30D4"? <N> y
    Purge registered application "30E3"? <N> y
    Purge registered application "30E8"? <N> y
    Purge registered application "45E9"? <N> y
    Purge registered application "45F3"? <N> y
    Purge registered application "45F8"? <N> y
    Purge registered application "4602"? <N> y
    Purge registered application "45FD"? <N> y
    Purge registered application "46A7"? <N> y
    Purge registered application "46F2"? <N> y
    Purge registered application "473C"? <N> y
    Purge registered application "4765"? <N> y
    Purge registered application "478E"? <N> y
    Purge registered application "47E5"? <N> y
    Purge registered application "47EA"? <N> y
    Purge registered application "47EF"? <N> y
    Purge registered application "47F4"? <N> y
    Purge registered application "47F9"? <N> y
    Purge registered application "47E0"? <N> y
    Purge registered application "47DB"? <N> y
    Purge registered application "47D6"? <N> y
    Purge registered application "47D1"? <N> y
    Purge registered application "47B7"? <N> y
    Purge registered application "4971"? <N> y
    Purge registered application "499A"? <N> y
    Purge registered application "4AEC"? <N> y
    Purge registered application "4B36"? <N> y
    Purge registered application "4C09"? <N> y
    Purge registered application "ACAD_DIMASSOC_CALC_DIMLFAC"? <N> y
    Purge registered application "ACAD_DIMASSOC_DIMLFAC"? <N> y
    Purge registered application "ACAD_DIMASSOC_OVERRIDDEN_DIMLFAC"? <N> y
    Purge registered application "AEC_KEYNOTE_ANNO_INFO"? <N> y
    Purge registered application "AEC_KEYNOTE_LEGEND"? <N> y
    Purge registered application "D84"? <N> y
    Purge registered application "D89"? <N> y
    Purge registered application "D8E"? <N> y
    Purge registered application "D93"? <N> y
    Purge registered application "D98"? <N> y
    Purge registered application "D9D"? <N> y
    Purge registered application "DA2"? <N> y
    Purge registered application "DA7"? <N> y
    Purge registered application "DAC"? <N> y
    Purge registered application "DB1"? <N> y
    Purge registered application "D6B"? <N> y
    Purge registered application "F73"? <N> y
    Purge registered application "D66"? <N> y
    Purge registered application "F77"? <N> y
    Purge registered application "F83"? <N> y
    Purge registered application "F86"? <N> y
    Purge registered application "F8E"? <N> y
    Purge registered application "3"? <N> y
    Purge registered application "F91"? <N> y
    Purge registered application "F99"? <N> y
    Purge registered application "F9C"? <N> y
    Purge registered application "FA5"? <N> y
    Purge registered application "FA8"? <N> y
    Purge registered application "FB1"? <N> y
    Purge registered application "FB4"? <N> y
    Purge registered application "FBC"? <N> y
    Purge registered application "FBF"? <N> y
    Purge registered application "FC7"? <N> y
    Purge registered application "FCA"? <N> y
    Purge registered application "FD2"? <N> y
    Purge registered application "FD5"? <N> y
    Purge registered application "1231"? <N> y
    Purge registered application "1238"? <N> y
    Purge registered application "1279"? <N> y
    Purge registered application "127E"? <N> y
    Purge registered application "12C0"? <N> y
    Purge registered application "12EA"? <N> y
    Purge registered application "MStation"? <N> y
    Purge registered application "2D7D"? <N> y
    Purge registered application "2D82"? <N> y
    Purge registered application "2DCF"? <N> y
    Purge registered application "2DFC"? <N> y
    Purge registered application "2E91"? <N> y
    Purge registered application "2EBA"? <N> y
    Purge registered application "2EE6"? <N> y
    Purge registered application "2F0F"? <N> y
    Purge registered application "1395"? <N> y
    Purge registered application "1378"? <N> y
    Purge registered application "14F6"? <N> y
    Purge registered application "5C95"? <N> y
    Purge registered application "5D8A"? <N> y
    Purge registered application "5DB4"? <N> y
    Purge registered application "5ECD"? <N> y
    Purge registered application "5EC8"? <N> y
    Purge registered application "5F56"? <N>
    Purge registered application "13F3"? <N> y
    Purge registered application "5A33"? <N> y
    Purge registered application "5A39"? <N> y
    Purge registered application "5A7C"? <N> y
    Purge registered application "5A3D"? <N> y
    Purge registered application "5A45"? <N> y
    Purge registered application "5A48"? <N> y
    Purge registered application "5A50"? <N> y
    Purge registered application "5A53"? <N> y
    Purge registered application "5AB3"? <N> y
    Purge registered application "5ADD"? <N> y
    Purge registered application "2B84"? <N> y
    Purge registered application "2BAD"? <N> y
    Purge registered application "2B7F"? <N> y
    Purge registered application "2C19"? <N> y
    Purge registered application "2C5E"? <N> y
    Purge registered application "2C7C"? <N> y
    Purge registered application "2F77"? <N> y
    Purge registered application "2F7C"? <N> y
    Purge registered application "3004"? <N> y
    Purge registered application "2F81"? <N> y
    Purge registered application "3001"? <N> y
    Purge registered application "2FF9"? <N> y
    Purge registered application "2FF5"? <N> y
    Purge registered application "2F86"? <N> y
    Purge registered application "B93"? <N>
    Purge registered application "BB9"? <N> y
    Purge registered application "BBE"? <N> y
    Purge registered application "BC3"? <N> y
    Purge registered application "BC8"? <N> y
    Purge registered application "BCD"? <N> y
    Purge registered application "BD2"? <N> y
    Purge registered application "BA5"? <N> y
    Purge registered application "DEF"? <N> y
    Purge registered application "BB4"? <N> y
    Purge registered application "DF2"? <N> y
    Purge registered application "DFB"? <N> y
    Purge registered application "DFE"? <N> y
    Purge registered application "E06"? <N> y
    Purge registered application "E09"? <N> y
    Purge registered application "E11"? <N>
    Purge registered application "E14"? <N>
    Purge registered application "E1D"? <N>
    Purge registered application "E20"? <N>
    Purge registered application "E29"? <N>
    Purge registered application "E2C"? <N>
    Purge registered application "E34"? <N>
    Purge registered application "E37"? <N>
    Purge registered application "E3F"? <N>
    Purge registered application "E42"? <N>
    Purge registered application "E4A"? <N>
    Purge registered application "E4D"? <N>
    Purge registered application "BAA"? <N>
    Purge registered application "BAF"? <N>
    Purge registered application "1122"? <N>
    Purge registered application "11B8"? <N>
    Purge registered application "1143"? <N>
    Purge registered application "11BC"? <N>
    Purge registered application "11C4"? <N>
    Purge registered application "11C7"? <N>
    Purge registered application "11CF"? <N>
    Purge registered application "11D2"? <N>
    Purge registered application "1139"? <N>
    Purge registered application "114D"? <N>
    Purge registered application "1157"? <N>
    Purge registered application "1161"? <N>
    Purge registered application "116B"? <N>
    Purge registered application "1175"? <N>
    Purge registered application "11A9"? <N>
    Purge registered application "1303"? <N>
    Purge registered application "1396"? <N>
    Purge registered application "13EE"? <N>
    Purge registered application "13E9"? <N>
    Purge registered application "1466"? <N>
    Purge registered application "1461"? <N>
    Purge registered application "1495"? <N>
    Purge registered application "145C"? <N>
    Purge registered application "1470"? <N>
    Purge registered application "146B"? <N>
    Purge registered application "1556"? <N>
    Purge registered application "157E"? <N>
    Purge registered application "15BF"? <N>
    Purge registered application "1607"? <N>
    Purge registered application "1820"? <N>
    Purge registered application "15F9"? <N>
    Purge registered application "15FE"? <N>
    Purge registered application "1603"? <N>
    Purge registered application "165F"? <N>
    Purge registered application "165A"? <N>
    Purge registered application "15F4"? <N>
    Purge registered application "1608"? <N>
    Purge registered application "1755"? <N>
    Purge registered application "17D6"? <N>
    Purge registered application "1771"? <N>
    Purge registered application "17D9"? <N>
    Purge registered application "17E1"? <N>
    Purge registered application "17E4"? <N>
    Purge registered application "17EF"? <N>
    Purge registered application "17F7"? <N>
    Purge registered application "1802"? <N>
    Purge registered application "1805"? <N>
    Purge registered application "180D"? <N>
    Purge registered application "1810"? <N>
    Purge registered application "A2E"? <N>
    Purge registered application "1785"? <N>
    Purge registered application "181E"? <N>
    Purge registered application "1821"? <N>
    Purge registered application "1828"? <N>
    Purge registered application "182B"? <N>
    Purge registered application "1832"? <N>
    Purge registered application "1835"? <N>
    Purge registered application "183C"? <N>
    Purge registered application "183F"? <N>
    Purge registered application "1846"? <N>
    Purge registered application "1850"? <N>
    Purge registered application "1861"? <N>
    Purge registered application "1864"? <N>
    Purge registered application "186B"? <N>
    Purge registered application "186E"? <N>
    Purge registered application "1875"? <N>
    Purge registered application "1878"? <N>
    Purge registered application "187F"? <N>
    Purge registered application "1882"? <N>
    2001-10
    Waukegan, IL
    52
    After saving the drawing that had been purged, I noticed that many of the reg apps reloaded. Still getting the message that it can't find aeccivil's enabler.
    2002-09
    Madison, WI
    5,645
    Run the purge reg apps on all x-refs first. Then your final drawing. Any drawing or block that contains any reg app that in inserted or x-refed into another drawing will now contain all the reg apps from the inserted drawing. On the AEC civil question, that sounds like it might be a proxy object. You could try using superpurge, but make sure you do that on a copy as no one knows what that program will delete. All I know is that if I don't want something in a drawing and I know the name of it, I can get rid of it with that. But I've also had this cause currupt drawings.
    Hope this helps.
    Dave Peterson
    BIM Coordinator
    Acad - 2019 - Revit 2020 w/ BIM 360 - Navisworks - 3ds 2020 - Ensacpe - Lumion - Win 7 64 - i7-8086K 4.0GHz 32GB Ram - Nvidia Quadro P2000
  1. 2013: mur existant - le casse tête
    By damien.leonard677035 in forum Revit Architecture - Général
    Last Post: 2014-07-29, 05:59 AM
  2. 2011: Méthode de travail sur de l'existant
    By dapperdan in forum Revit Architecture - Général
    Last Post: 2010-07-12, 01:19 PM
  3. copier d'un feuille existant
    By ktsnguyenhoanghieu in forum Revit Architecture - Général
    Last Post: 2009-09-19, 07:31 AM
  4. apparence phase existant
    By acor in forum Revit Architecture - Général
    Last Post: 2008-11-09, 07:54 PM
  5. Existant et Projeté
    By batproj in forum Revit Architecture - Général
    Last Post: 2008-03-21, 08:54 AM
