Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: Run a command at AutoCAD LT Startup
    2006-05
    139
    Default Run a command at AutoCAD LT Startup
    Hi all,
    I want to run the undefine command when AutoCAD (LT 2007) starts. I tried switches at the shortcut icon but they don't work. I would like to have some commands undefined right from when AutoCAD loads, whether somebody starts AutoCAD LT from the shortcut, start menu of Windows, double click on a drawing file, or whatever other way they can start AutoCAD.
    Please note that LISP is not an option.
    Any help would be much appreciated.
    Thanks!
    Turlock, CA
    6,420
    Default Re: Run a command at AutoCAD LT Startup
    Did you try the "/b" switch? i.e. scripts?
    C:> ED WORKING....
    LinkedIn
    2006-05
    139
    Quote Originally Posted by Ed Jobe
    Hi Ed. Thanks for the reply. I tried the /b switch but it didn't work. I also have the feeling (and please correct me if I am wrong) that this method only works if you double click on the shortcut. If you double click on a drawing, the the commands are defined as normal. Same if you go QNew, New and Open. Please correct me if I am wrong.
    Thanks.
    Turlock, CA
    6,420
    Correct, the script will only run if you use the shortcut.
    C:> ED WORKING....
    LinkedIn
    2006-05
    139
    Is there any way to undefine a command and keep it like that every time AutoCAD starts no matter how it starts and no matter how drawing are opened (QNew, New, Open, double click on a file, etc)?
    Turlock, CA
    6,420
    I don't see any other way with LT. The only other thing I can think of is to disassociate acad from the dwg extension so that you have to use the shortcut to open.
    C:> ED WORKING....
    LinkedIn
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    It still would not work after it is already opened. Is this a management issue?
    2006-05
    139
    Quote Originally Posted by Opie
    No not really a management issue. It is more like playing safe. You can't really use what is not available to you. And since we are upgrading all the workstations, it is a good opportunity to introduce some new things like undefine some commands and options that only the CAD Management team should be using anyway. You take away the temptation in a way.
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by Inferno6919
    Remove them from the menu would limit some. But LT is not a very customizable platform.
    2006-05
    139
    How would anyone udefine commands the way I want to do it, if they had full AutoCAD? Would it be with LISP or is there another way to do it when you have full AutoCAD?
    Thanks for the replies.
  1. How can I make a startUp Exe for Startup AutoCAD
    By 740176597380946 in forum ARX
    Last Post: 2013-05-24, 05:36 AM
  2. 2012: AutoCAD startup
    By sdeyo in forum AutoCAD General
    Last Post: 2011-04-26, 01:19 PM
  3. misspelled command issues upon startup
    By cwjean76 in forum AutoCAD General
    Last Post: 2010-09-13, 09:21 PM
  4. command line not loading on startup
    By WesternSoul in forum AutoCAD Customization
    Last Post: 2008-12-23, 10:47 PM
  5. Replies: 15
    Last Post: 2007-08-09, 09:30 PM
